gilbert
Member since April 2018
Newb
Apr 21, 2018 13:12:26 GMT -5
via mobile
Post by gilbert on Apr 21, 2018 13:12:26 GMT -5
Want to say hi to everyone. Just started rock polishing I got a few Boley Agate and a thumblers UV18 to play with. Anyone live near Muskogee Oklahoma
Newb
May 13, 2018 22:37:40 GMT -5
Post by TheRock on May 13, 2018 22:37:40 GMT -5
Newb
May 14, 2018 1:25:30 GMT -5
Post by gmitch067 on May 14, 2018 1:25:30 GMT -5
Welcome gilbert from Northern California. I like my UV-18 better than the UV-10... the action seems smoother... But it is a noisy beast!!! How are you preparing your rocks before putting them into the UV-18? Do you rotary tumble them first in coarse grit before going to the vibe? (Note: the UV-18 bowl will wear away very quickly if you run sharp edged rocks and coarse grit in it. I have found that only 220 grit and finer should be run in the vibe.) Glenn P.S. ... I pretty much said the same thing in your previous thread... but I think the info is important enough to be repeated. (sorry?)
