geostrong
Life is like saltation, you have to bounce off of others to become a well-rounded individual
Member since April 2018
Post by geostrong on Apr 26, 2018 10:51:59 GMT -5
I recently got into my buckets of fluorite that I collected before winter. I just did some test cuts to see what I had. I will be trying to cab this as time allows and to test the viability of this material. Cool stuff, but not sure if I 'love' it... Would you like to work with this material? Brec. Fluorite cuts dry by Thomas Strong, on Flickr Brec. Fluorite cuts wet by Thomas Strong, on Flickr Brec. Fluorite by Thomas Strong, on Flickr Brec. Fluorite congl. by Thomas Strong, on Flickr Brec. Fluorite white veins by Thomas Strong, on Flickr Brec. Fluorite, microshift by Thomas Strong, on Flickr Brec. Fluorite w/ K-spar by Thomas Strong, on Flickr Brec. Fluorite & outer by Thomas Strong, on Flickr
Post by rockjunquie on Apr 26, 2018 10:54:28 GMT -5
Wow!!! That's really pretty stuff. Let us know how it works up. I'd give it a shot. It seems it might be crumbly to slab, but I'm sure you could get some cabs out of it.
Post by MsAli on Apr 26, 2018 11:17:13 GMT -5
For sure want to see how this comes out. Fluorite is always a fav of mine
NDK
Post by NDK on Apr 30, 2018 19:09:31 GMT -5
geostrong Beautiful stuff! Wanna sell a few pieces?
Post by Pat on Apr 30, 2018 19:15:55 GMT -5
Those brecciated pieces have a lot going for them. Let us know how it works out. Pretty stuff!
geostrong
Post by geostrong on May 1, 2018 9:31:32 GMT -5
Soooo, I have done a cab of some this fluorite. I have been pretty busy and have only gotten the one done, I will try some of the others asap, but I may not be able to post a pic for a while. I have been in talks with myself for many days on whether or not I should post a pic of this lumpy thing. If I could personify the piece it would definitely swing on ropes from bell towers and fall in love with Esmeralda. Herein lies my problem: I decided to cab one of the pieces that had pink feldspar in it (pic 7, second to last). I was correct that the country rock was incorporated in this outcrop of fluorite. What my brain did not realize was the fact that if I had feldspar from the country granite I would likely have quartz as well. I had quartz. So, the piece has hardnesses of 3, 6, & 7 . My amateur skills were not prepared for this. The cab is lumpy, especially where there is quartz. Then, to top off the problems, some of the feldspar had altered to clay and will not take a polish. Without further ado and with much hesitation here is my first cab of this fluorite. I had done an egg shape in hopes I could use this for the April FCC. 20180427_160458 by Thomas Strong, on Flickr NDK I could be persuaded to let some of this go Send me a PM if interested (anyone) and I can do some quick cuts to determine fill pattern and post pics, or if you want the surprise yourself I can send chunks.
Post by rockjunquie on May 1, 2018 10:02:15 GMT -5
Soooo, I have done a cab of some this fluorite. I have been pretty busy and have only gotten the one done, I will try some of the others asap, but I may not be able to post a pic for a while. I have been in talks with myself for many days on whether or not I should post a pic of this lumpy thing. If I could personify the piece it would definitely swing on ropes from bell towers and fall in love with Esmeralda. Herein lies my problem: I decided to cab one of the pieces that had pink feldspar in it (pic 7, second to last). I was correct that the country rock was incorporated in this outcrop of fluorite. What my brain did not realize was the fact that if I had feldspar from the country granite I would likely have quartz as well. I had quartz. So, the piece has hardnesses of 3, 6, & 7 . My amateur skills were not prepared for this. The cab is lumpy, especially where there is quartz. Then, to top off the problems, some of the feldspar had altered to clay and will not take a polish. Without further ado and with much hesitation here is my first cab of this fluorite. I had done an egg shape in hopes I could use this for the April FCC. 20180427_160458 by Thomas Strong, on Flickr NDK I could be persuaded to let some of this go Send me a PM if interested (anyone) and I can do some quick cuts to determine fill pattern and post pics, or if you want the surprise yourself I can send chunks. That doesn't look so bad. Some stones undercut- that's just the way they are. Try not to use much pressure on the softer wheels. I bet you pull some off much nicer in the future- now that you know what you are working with.
Post by MsAli on May 1, 2018 10:13:26 GMT -5
Doesn't look that bad. Better that I would of done
geostrong
Post by geostrong on May 1, 2018 12:01:11 GMT -5
Thank you rockjunquie, I will try to use less pressure on the soft wheels and I appreciate the advice
Post by fernwood on May 1, 2018 12:16:55 GMT -5
That looks pretty good considering all the different harness levels.
vwfence
Post by vwfence on May 2, 2018 17:25:02 GMT -5
Where was this found ? I have a big chunk of some that's similar that came from Mexico
geostrong
Post by geostrong on May 3, 2018 7:49:13 GMT -5
Where was this found ? I have a big chunk of some that's similar that came from Mexico This was found in Colorado. I'd be interested in seeing the stuff from Mexico
vwfence
Post by vwfence on May 3, 2018 9:43:19 GMT -5
Ill try and get a picture later today when I get back from the Doctors
Post by drocknut on May 3, 2018 16:35:10 GMT -5
cool looking material
