bmw2002
Member since April 2017
Post by bmw2002 on Apr 27, 2018 15:50:37 GMT -5
I believe my old Star Diomond 10" motor is about to conk. It hesitates a lot these days, so it could be the capacitor, or something else that needs an overhaul. My question is that original GE motor is a 3/4 HP @1725 rpm's. I would like to upgrade to a 1 HP with the same 1725 rpm's if that is possible? Should I stick with the mfg's standard 3/4, or is there any benefit in increasing the HP to 1.00? Thanks with any comments.
Post by parfive on Apr 27, 2018 16:27:03 GMT -5
My 14” Lortone runs just fine with a 1/3 hp motor.
Hard to believe that ¾ horse is original equipment on a ten-inch saw.
Post by parfive on Apr 27, 2018 16:42:24 GMT -5
Hmm? Covington website no longer lists motor size for their big slab saws, 18” and up.
Covington's Combination Slab and Trim Saws feature a 1/2hp motor on all units: 12” 14” & 16”.
Post by Drummond Island Rocks on Apr 27, 2018 16:51:07 GMT -5
My beacon star 14" came stock with 1/2 Hp and that has always worked great. Never heard of a 10" saw needing that large of a motor unless it were part of one of the old combo units where the saw and several grinding wheels we sharing a motor.
Post by Drummond Island Rocks on Apr 27, 2018 16:53:48 GMT -5
If your saw is the same as this one it should be 1/3 HP Chuck
Post by woodman on Apr 27, 2018 17:08:24 GMT -5
my 10 inch Lortone slab saw has a 1/3 hp motor at 1725 rpm. It works great.
Post by pauls on Apr 27, 2018 22:58:40 GMT -5
Hows your mechanical aptitude? If you can handle tools reasonably competantly then undoing a few bolts and having a look could be worthwhile. Unplugged from the electricity first of coarse, wires probably will be push on terminals, if you need to remove any make yourself a diagram and tag the wires but you should be able to just pop the end off enough to get a look at the switch points, one of them will possibly be dirty, clean it with a small piece of wet and dry sandpaper. reassemble and see how it goes. It's also possibly the capacitor which only cost around $10 at your local electrical wholesaler.
While you have it apart oil the bearings.
Easy peasy, if you seriously stuff something remember you were going to throw it away anyway.
bmw2002
Post by bmw2002 on May 3, 2018 18:38:59 GMT -5
Thanks to everyone. After messing with the arbor shaft, and pulleys on the saw, I noted that the set screw on the pulley of the arbor shaft was not connecting to the key. For some reason it had sheared off. Got a new one, put some spacers between the reservoir and the motor which helped tightened the loose belt as it had too much play. Cleaned up the motor, put a new blade in, and am happy to say that I am now slip, slabbing away!! Thanks to all of you for your help. I would have never figured it out. Yes, I agree that a 1/3 HP, 1725 RPM is more than sufficient. Only thing is that Star Diamond put in a 3/4 HP unit as original equipment, as I bought this saw used. Maybe some one previously did a change out. Works like a champ now. I am a SD fan!!
Post by johnjsgems on May 4, 2018 11:18:43 GMT -5
Glad you got it done cheap. For the record, sometimes a vastly unloaded motor will run hot for some reason. Best to run somewhere in the 2/3-3/4 of rated running amps. Always good to periodically blow out motors with compressed air. A buildup of dust on windings can cause problems over time. Just blow air through any air vents.
