foxtrotllf
Member since April 2018
Post by foxtrotllf on Apr 28, 2018 13:18:25 GMT -5
Hi All, I started rockhounding and tumbling about a year ago. Still very much an amateur. I just bought a vibe and haven't really figured out what works best for media.
nchillbilly
Member since January 2018
Hi
Apr 28, 2018 13:23:04 GMT -5
Post by nchillbilly on Apr 28, 2018 13:23:04 GMT -5
Welcome to the forum from North Carolina. There are many great tumblers on here that can probably answer just about any question you have.
El JeffA
Member since February 2016
Hi
Apr 28, 2018 14:05:10 GMT -5
Post by El JeffA on Apr 28, 2018 14:05:10 GMT -5
Hi. Welcome o the forum from Florida. I use ceramic media purchased from The Rock Shed on everything in prepolish and polish. I use the Lot-O vibe for those stages. What vibe did you get?
Hi
Apr 28, 2018 14:11:58 GMT -5
Post by Pat on Apr 28, 2018 14:11:58 GMT -5
Not a tumbler, but welcome from California.
Hi
Apr 28, 2018 14:14:54 GMT -5
Post by vegasjames on Apr 28, 2018 14:14:54 GMT -5
Welcome to the forum.
Hi
Apr 28, 2018 17:51:09 GMT -5
Post by hummingbirdstones on Apr 28, 2018 17:51:09 GMT -5
Welcome from Northern Arizona!
Hi
Apr 28, 2018 21:06:50 GMT -5
Post by gmitch067 on Apr 28, 2018 21:06:50 GMT -5
Welcome to the Forum from Northern California! Large and small ceramic media from The Rock Shed is my GoTo media for vibes. The ceramic media sold there is low in abrasive content I am told... which is desirable in that you don't want the embedded abrasives ruining a shine in the finer grit stages. I use twice as much large ceramic media as small (the small wears out faster and begins to accumulate at the outer edges of the vibe run. As they get smaller, they climb the inner walls of the vibe bowl and overflow - in pieces - to the table below... a bit messy... but more annoying than anything). I am now experimenting using polished pea gravel (aquarium gravel) and am very pleased at how well it does... especially in the UV-10 and UV-18. I am beginning to use it in the Lot-O and the Mini-Sonic 4 processing small Turritella shells... no probs yet. Just make sure you run the pea gravel through all stages to get them polished first before using it in the finer stages and polish. Then sift through the gravel to remove the real small stuff and rocks that are jagged or porous and could trap grit from previous stages. (thanks jamesp!!!) Glenn
Hi
Apr 29, 2018 8:58:43 GMT -5
Post by Fossilman on Apr 29, 2018 8:58:43 GMT -5
WElcome to the forum!!
Post by Noosh9057 on Apr 30, 2018 9:13:14 GMT -5
Roger
Hi
Apr 30, 2018 9:16:28 GMT -5
Post by rockjunquie on Apr 30, 2018 9:16:28 GMT -5
Welcome from VA.
Hi
May 13, 2018 22:18:59 GMT -5
Post by TheRock on May 13, 2018 22:18:59 GMT -5
