Post by TheRock on May 2, 2018 1:33:28 GMT -5
Here is an Add On that I did to the shop that will make the shop a whole lot safer and will give you peace of mind while you are away from home and your tumblers are spinning.
Post by gmitch067 on May 2, 2018 2:05:00 GMT -5
Thank you Duke! Good presentation... and I liked that you included the wiring diagram and parts descriptions.
Glenn
Post by fantastic5 on May 2, 2018 8:12:50 GMT -5
Nicely shot and explained. And your studio is still WAY to clean
NRG
Member since February 2018
Post by NRG on May 2, 2018 10:16:46 GMT -5
Bravo!
Post by Noosh9057 on May 2, 2018 11:46:34 GMT -5
How would I fined A rip switch for one Tumblr. Preferably something I can plug into the wall then plug the Tumblr in. Do they have something like this that would be super easy for someone to plug one Tumblr in.
Roger
NRG
Post by NRG on May 2, 2018 13:11:44 GMT -5
Hi Duke,
That little video has tremendous value for many of us. I'd like to extend my gratitude for you taking the time show in excellent detail how you solved this problem. Well done!
Thank you sir!
Post by Noosh9057 on May 2, 2018 14:04:01 GMT -5
NRG
Post by NRG on May 2, 2018 17:21:46 GMT -5
Post by Noosh9057 on May 2, 2018 18:13:28 GMT -5
Post by TheRock on May 2, 2018 19:30:46 GMT -5
Thanks Guys! Yes that would work Rodge no problemo, and the nice thing about AMAZON is you can send it back mo problemo if it don't work! Which I think it will by the description.
Post by Noosh9057 on May 4, 2018 18:59:31 GMT -5
Thanks Guys! Yes that would work Rodge no problemo, and the nice thing about AMAZON is you can send it back mo problemo if it don't work! Which I think it will by the description. This item came today. It works beautifully.
Post by TheRock on May 5, 2018 19:24:55 GMT -5
Thanks Guys! Yes that would work Rodge no problemo, and the nice thing about AMAZON is you can send it back mo problemo if it don't work! Which I think it will by the description. This item came today. It works beautifully. Yep, makes no difference how you do it as long as it gets done. Things happen and leaving a tumbler unattended when the power goes off is a crap shoot. It may not come back on and start correctly? This way you can make sure all is okay! ~Duke
Post by Noosh9057 on May 5, 2018 20:30:04 GMT -5
This item came today. It works beautifully. Yep, makes no difference how you do it as long as it gets done. Things happen and leaving a tumbler unattended when the power goes off is a crap shoot. It may not come back on and start correctly? This way you can make sure all is okay! ~Duke Thanks so much.
melf77
Member since July 2017
Post by melf77 on May 11, 2018 6:12:37 GMT -5
Nicely shot and explained. And your studio is still WAY to clean Ditto to that. makes me look like a slob with my tumblers.
Post by melhill1659 on May 13, 2018 20:45:57 GMT -5
How would I fined A rip switch for one Tumblr. Preferably something I can plug into the wall then plug the Tumblr in. Do they have something like this that would be super easy for someone to plug one Tumblr in. Roger
Post by jamesp on May 13, 2018 21:07:47 GMT -5
Neatness, nice shop. You probably do meticulous work. Impressive
rads
Making clay each day!
Member since April 2018
Post by rads on May 14, 2018 14:50:27 GMT -5
Great video, epic shop...shame, envy, not sure which is strongest. That is such a great idea for fire safety. Will be installing in my shop as soon as the parts arrive, Michigan weather causes outages with frustrating regularity and my shop is not on the generator circuits. Thanks.
Post by TheRock on Nov 3, 2018 3:29:54 GMT -5
How would I fined A rip switch for one Tumblr. Preferably something I can plug into the wall then plug the Tumblr in. Do they have something like this that would be super easy for someone to plug one Tumblr in. Roger Mel Sorry for the late reply I just seen this. Mel this would work for 1 tumbler.
mooresean68
Post by mooresean68 on Nov 3, 2018 18:25:26 GMT -5
They say timing is everything ... we lost power yesterday and browsing the recent posts here I came across this thread again for the second time (takes me several tries to learn something luckily we were home and I could unplug the tumblers before the power came back on some 6 hour later. To have the security of knowing there exists this kind of trip circuit and with a bit of searching I figure this combination ought to suit my needs quite well. As recommended in this thread for a single tumbler the GFCI cord. www.amazon.com/gp/product/B01C0NPJGE/Tower Manufacturing 30326806-08 Manual-Reset 15 AMP Right Angle GFCI Cord, 9 Inches, Yellow And then for 3 connected devices an individually switched power strip! www.amazon.com/gp/product/B0068LACFI/Tripp Lite 7 Outlet (6 Individually Controlled) Surge Protector Power Strip, 6ft Cord I've got two Lortone QT66's rated at .85A and one Lortone 3A rated at .53A, the total amperage easily covered by the 15A on the GFCI cord rating. Big thanks to TheRock for the quality video and guidance and the peace of mind that comes with! -Sean
Post by TheRock on Nov 3, 2018 19:48:19 GMT -5
They say timing is everything ... we lost power yesterday and browsing the recent posts here I came across this thread again for the second time (takes me several tries to learn something luckily we were home and I could unplug the tumblers before the power came back on some 6 hour later. To have the security of knowing there exists this kind of trip circuit and with a bit of searching I figure this combination ought to suit my needs quite well. As recommended in this thread for a single tumbler the GFCI cord. www.amazon.com/gp/product/B01C0NPJGE/Tower Manufacturing 30326806-08 Manual-Reset 15 AMP Right Angle GFCI Cord, 9 Inches, Yellow And then for 3 connected devices an individually switched power strip! www.amazon.com/gp/product/B0068LACFI/Tripp Lite 7 Outlet (6 Individually Controlled) Surge Protector Power Strip, 6ft Cord I've got two Lortone QT66's rated at .85A and one Lortone 3A rated at .53A, the total amperage easily covered by the 15A on the GFCI cord rating. Big thanks to TheRock for the quality video and guidance and the peace of mind that comes with! -Sean Your more than Welcome Sean glad I could Help! Be Safe!
