Post by miket on May 7, 2018 18:20:32 GMT -5
Quick question, should I be cleaning agates with a brass brush???
Post by drocknut on May 7, 2018 18:57:17 GMT -5
I just use a bristle brush like a nail brush. Don't see a need to use a brass brush just for cleaning but that's just my opinion.
Post by rmf on May 7, 2018 19:24:17 GMT -5
I would use anything that works. But why a brass brush? Are you hoping to leave yellow brass streaks on the agate? Agate (Chalcedony and Quartz family) has a Moh's hardness of 7, a steel brush would have a Mohs hardness between 5.5-6 and a brass brush would be a hardness of about 3. It might be faster to clean it in a tumbler or with a sand blaster or possibly acid depending on the type of host rock/coating you are trying to clean off.
Post by miket on May 8, 2018 8:08:18 GMT -5
I'm mostly trying to clean off the discoloration/weatherization on agates to reveal fairburns. I'm trying iron out in some of them based on some of what I've read here. I don't want to tumble or polish them, they're more collectible in their natural state from what I understand.
geostrong
Life is like saltation, you have to bounce off of others to become a well-rounded individual
Member since April 2018
Post by geostrong on May 8, 2018 8:32:49 GMT -5
As rmf said, the brass will leave a brassy sheen on your agate. This could potentially be neat if done correctly, but if you want the agates au naturale I would use a stiff non-metallic brush. I love using old toothbrushes for cleaning rocks. Rocks are like teeth right? They work great. That being said, discoloration can often be under the surface and will require a more physical approach. Good luck!
Post by Peruano on May 8, 2018 15:21:41 GMT -5
I probably no very little about valuation of Fairburns, but it seems likely that the value of an agate depends on being able to see something of whats inside, Hence many are windowed with one face polished but they are not slabbed or tumbled or polished on all surfaces like some specimens might be. True if the internal structure can be seen with no significant grinding, its a winner, but most agates show a good bit of weathering and that white film is hard stuff to remove without significant grinding and or polishing. Scrubbing an agate can only go so far. Talk to the folks that collect and prepare them.
