braat
Member since December 2016
Post by braat on May 13, 2018 22:07:26 GMT -5
Same self collected rocks as in previous photos so nothing special except that overall shine is better than previous...three of them are wet shine like (can't see it in the photo so you'll have to trust me...wish I knew how to capture that but I'm working on it). Anyways every batch is a little better so things are headed in the right direction...
saxplayer
Member since March 2018
Post by saxplayer on May 13, 2018 22:44:07 GMT -5
Your shaping is fantastic. I think you’re doing well!
braat
Post by braat on May 13, 2018 23:59:57 GMT -5
Your shaping is fantastic. I think you’re doing well! Thanks...I'm getting more picky what comes out of the first stage as well as what goes into it...
Post by gmitch067 on May 14, 2018 1:13:15 GMT -5
Looking GOOD Glen braat. Good shape and very good polish! Glenn
braat
Post by braat on May 14, 2018 9:32:40 GMT -5
Looking GOOD Glen braat . Good shape and very good polish! Glenn Thanks Glenn (with 2 n's) ...one of us has our name spelled wrong
Post by Drummond Island Rocks on May 14, 2018 12:31:49 GMT -5
Very nice. Are a couple of those pet wood?
Post by aDave on May 14, 2018 13:04:01 GMT -5
Good job on the tumbles.
As far as capturing the shine, stay out of direct sunlight. I don't know the exact reason why, but the shine gets washed out and the camera can't pick it up. If you're using bulbs, they may have to be diffused for the same reason. Play with different light sources in your home, or photograph just inside of a window where it's bright outside.
In my house, since I don't have an artificial lighting setup, my "best" spot is underneath a skylight. Next is in the garage where I have daylight fluorescent bulbs. Hope this helps a bit.
braat
Post by braat on May 14, 2018 13:19:10 GMT -5
Very nice. Are a couple of those pet wood? Chuck Thanks...if you're referring to the 2 brown/black ones just below the coin, yes I think they are pet wood. Way back I got a big 5 inch tumbled pet wood chunk from my sister ( I think she bought it somewhere) and over her ownership years it cracked and got beaten up pretty good (kids) so when she passed away I got the rock and recently busted it up and tumbled the pieces....those are 2 of the larger pieces...so I lied about them all being self collected...I beg for RTH forgiveness
Post by Drummond Island Rocks on May 14, 2018 13:22:53 GMT -5
Very nice. Are a couple of those pet wood? Chuck Thanks...if you're referring to the 2 brown/black ones just below the coin, yes I think they are pet wood. Way back I got a big 5 inch tumbled pet wood chunk from my sister ( I think she bought it somewhere) and over her ownership years it cracked and got beaten up pretty good (kids) so when she passed away I got the rock and recently busted it up and tumbled the pieces....those are 2 of the larger pieces...so I lied about them all being self collected...I beg for RTH forgiveness Out of everything in that batch I would expect the pet wood to have the best polish. Was that the case? Chuck
braat
Post by braat on May 14, 2018 13:39:19 GMT -5
Thanks...if you're referring to the 2 brown/black ones just below the coin, yes I think they are pet wood. Way back I got a big 5 inch tumbled pet wood chunk from my sister ( I think she bought it somewhere) and over her ownership years it cracked and got beaten up pretty good (kids) so when she passed away I got the rock and recently busted it up and tumbled the pieces....those are 2 of the larger pieces...so I lied about them all being self collected...I beg for RTH forgiveness Out of everything in that batch I would expect the pet wood to have the best polish. Was that the case? Chuck No...the 3 on the outer edge to the right of the coin were the best although the pet wood was not far behind. I put a closer/better photo of those 3 in the Rock Identification forum...
braat
Post by braat on May 14, 2018 13:45:39 GMT -5
Good job on the tumbles. As far as capturing the shine, stay out of direct sunlight. I don't know the exact reason why, but the shine gets washed out and the camera can't pick it up. If you're using bulbs, they may have to be diffused for the same reason. Play with different light sources in your home, or photograph just inside of a window where it's bright outside. In my house, since I don't have an artificial lighting setup, my "best" spot is underneath a skylight. Next is in the garage where I have daylight fluorescent bulbs. Hope this helps a bit. Thanks... I will try your tips on my next batch photos and if they're better then I'll be blaming you
Post by MsAli on May 14, 2018 14:44:23 GMT -5
Nice batch!
