Post by fernwood on May 25, 2018 15:59:06 GMT -5
It is made in Santa Anna CA. Went to hardware store. Was the only customer there. Regular employee asked me what I needed. Just said 3 in One oil to get me in the right place. He took me to that section and asked what I was using it for. Told him I was looking for something better than 3 in One to lubricate bearings on a rock tumbler. Go figure. He does lapidary work as a hobby. Said the 3 in One reduces bearing life, due to the gumming effect. Said he used the turbine oil and it worked great. Price was less than the 3 in One. He uses it every other month in his tumblers and as needed for other equipment.
I purchased a small bottle.
Post by pauls on May 25, 2018 16:36:51 GMT -5
My dad was a maintenance man in a power station, he always used turbine oil on the ways (the moving slidy bits) of his lathe. He said it was some kind of vegetable oil.
Post by Rockoonz on May 25, 2018 18:22:03 GMT -5
Turbine oils are high quality mineral oils, most modern turbine oils have anti wear and anti corrosive additives. I used to get it in the zoom spout bottles for damper oil on SU and stromberg CD type carburetors on old euro cars.
According to Lortone no oil should ever be used on the plastic bearings on their small tumblers. We've never tested that, built and bought HD tumbler bases long ago with sealed bearing pillow blocks.
Post by fernwood on May 25, 2018 18:26:14 GMT -5
I have a duel barrel tumbler from Harbor Freight, Chicago Electric brand. Instructions and reviews said bearings must be oiled monthly. I was oiling once, maybe twice a day, even with the 3 in One oil.
Post by aDave on May 25, 2018 19:54:08 GMT -5
According to Lortone no oil should ever be used on the plastic bearings on their small tumblers. We've never tested that, built and bought HD tumbler bases long ago with sealed bearing pillow blocks. Hi Lee, do you have a specific source for this? I know Lortone mentions in their tumbler manuals that the motors don't need to be oiled, but as to the shaft bearings, the manuals mention a drop of oil for each bearing every 30 days. If there's something new out, that would be great. But, I just checked the manuals on the Lortone site, and they still read as they used to. Not looking to challenge - just looking for clarity. Thanks and regards.
Post by Rockoonz on May 25, 2018 21:37:13 GMT -5
According to Lortone no oil should ever be used on the plastic bearings on their small tumblers. We've never tested that, built and bought HD tumbler bases long ago with sealed bearing pillow blocks. Hi Lee, do you have a specific source for this? I know Lortone mentions in their tumbler manuals that the motors don't need to be oiled, but as to the shaft bearings, the manuals mention a drop of oil for each bearing every 30 days. If there's something new out, that would be great. But, I just checked the manuals on the Lortone site, and they still read as they used to. Not looking to challenge - just looking for clarity. Thanks and regards. 2nd hand from a rock club member, told me she called for advice and they said no oil, I wouldn't at all be surprised if it was BS. We were always fighting those tumbler bases for sure though.
Post by aDave on May 25, 2018 21:49:26 GMT -5
OK...thanks. Lortone IS pretty explicit about not over-oiling them, so perhaps between that and the fact that the motors don't require oil, maybe something got lost in translation on her behalf. Thanks for the reply.
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on May 26, 2018 0:52:21 GMT -5
Basically consider the Turbine oil to be a very high quality 10W oil. My little gas turbine only took 3000 gallons.
Post by grumpybill on May 26, 2018 10:54:58 GMT -5
I've been using turbine oil in a zoom spout bottle for the bushings (they're not "bearings) in my Lortone tumblers. It doesn't seem to accumulate as much gunk as the 3-in-1 type oil I had previously used.
