Post by phil on May 27, 2018 14:52:25 GMT -5
cleaning out more garage, so found more stuff to get rid of. make offer if interested. Will be several pics in this thread. Thanks! First photo is of some arbors. 1.25 hole size for bearings. Also 2 shafts with ball bearings, will need to be pressfit.
Post by phil on May 27, 2018 14:54:42 GMT -5
next up are some polishing pads, each has hone size marked. some are 6", some 8". All are brand new with rubber backing. again, make offer if interested.
Post by phil on May 27, 2018 14:56:23 GMT -5
next up is a base for a grinder motor. this came off a dual unit.
Post by phil on May 27, 2018 14:58:02 GMT -5
next is an on off toggle switch. I checked with meter, and it tests out perfect. I left some wires attached for those who need to learn how. again, Pm if interested...
Post by phil on May 27, 2018 15:00:27 GMT -5
next is grinding wheel housing that attaches to your grinder housing. Has shield, tool rest, grinding wheel. Pm, etc. includes the special washers needed to stabilize the grinding wheel.
Post by phil on May 27, 2018 15:03:02 GMT -5
and last are 2 ball bearings, 5/8 inch shaft, roll like a charm. Suggest you lube them when you mount them to continue long life. this for the bearings in the pic only, the washers go with the grinding wheel unit.
