Post by 1dave on Jun 15, 2018 5:18:06 GMT -5
Definition of astronomy - plural = astronomies:
the study of objects and matter outside the earth's atmosphere and of their physical and chemical properties
Astronomy Picture of the Day Archive
apod.nasa.gov/apod/archivepix.html
The Solar System
en.wikipedia.org/wiki/Solar_System
The Solar System is the gravitationally bound system comprising the Sun and the objects that orbit it, either directly or indirectly. Of the objects that orbit the Sun directly, the largest eight are the planets,[c] with the remainder being smaller objects, such as dwarf planets and small Solar System bodies. Of the objects that orbit the Sun indirectly, the moons, two are larger than the smallest planet, Mercury.
The Solar System formed 4.6 billion years ago from the gravitational collapse of a giant interstellar molecular cloud. The vast majority of the system's mass is in the Sun, with the majority of the remaining mass contained in Jupiter. The four smaller inner planets, Mercury, Venus, Earth and Mars, are terrestrial planets, being primarily composed of rock and metal. The four outer planets are giant planets, being substantially more massive than the terrestrials. The two largest, Jupiter and Saturn, are gas giants, being composed mainly of hydrogen and helium; the two outermost planets, Uranus and Neptune, are ice giants, being composed mostly of substances with relatively high melting points compared with hydrogen and helium, called volatiles, such as water, ammonia and methane. All eight planets have almost circular orbits that lie within a nearly flat disc called the ecliptic.
The Solar System also contains smaller objects.[e] The asteroid belt, which lies between the orbits of Mars and Jupiter, mostly contains objects composed, like the terrestrial planets, of rock and metal. Beyond Neptune's orbit lie the Kuiper belt and scattered disc, which are populations of trans-Neptunian objects composed mostly of ices, and beyond them a newly discovered population of sednoids. Within these populations are several dozen to possibly tens of thousands of objects large enough that they have been rounded by their own gravity.[10] Such objects are categorized as dwarf planets. Identified dwarf planets include the asteroid Ceres and the trans-Neptunian objects Pluto and Eris.[e] In addition to these two regions, various other small-body populations, including comets, centaurs and interplanetary dust clouds, freely travel between regions. Six of the planets, at least four of the dwarf planets, and many of the smaller bodies are orbited by natural satellites,[f] usually termed "moons" after the Moon. Each of the outer planets is encircled by planetary rings of dust and other small objects.
The solar wind, a stream of charged particles flowing outwards from the Sun, creates a bubble-like region in the interstellar medium known as the heliosphere. The heliopause is the point at which pressure from the solar wind is equal to the opposing pressure of the interstellar medium; it extends out to the edge of the scattered disc. The Oort cloud, which is thought to be the source for long-period comets, may also exist at a distance roughly a thousand times further than the heliosphere. The Solar System is located in the Orion Arm, 26,000 light-years from the center of the Milky Way.
The Milky Way Galaxy
This picture of the nearby galaxy NGC 6744, a Milky Way look-alike, was taken with the Wide Field Imager on the MPG/ESO 2.2-metre telescope at La Silla. - Credit: ESO
Milky Way Galaxy: Facts About Our Galactic Home
By Nola Taylor Redd, Space.com Contributor | November 14, 2017 10:00am ET
The Milky Way Galaxy is most significant to humans because it is home sweet home. But when it comes down to it, our galaxy is a typical barred spiral, much like billions of other galaxies in the universe. Let's take a look at the Milky Way.
Location, location, location
A glance up at the night sky reveals a broad swath of light. Described by the ancients as a river, as milk, and as a path, among other things, the band has been visible in the heavens since Earth first formed. In reality, this intriguing line of light is the center of our galaxy, as seen from one of its outer arms.
Understanding the structure of the Milky Way has long been challenging. The solar system sits on the outer edges of one arm in a disk of material, and no one can see across the dense center to the other side.
"The sun's location within the dust-obscured galactic disk is a complicating factor to observe the galactic structure," Denilso Camargo, of the Federal University of Rio Grande do Sul in Brazil, said in a statement.
The Milky Way is a barred spiral galaxy, about 100,000 light-years across. If you could look down on it from the top, you would see a central bulge surrounded by four large spiral arms that wrap around it. Spiral galaxies make up about two-third of the galaxies in the universe. [Infographic: Our Milky Way Galaxy: A Traveler's Guide]
Unlike a regular spiral, a barred spiral contains a bar across its center region, and has two major arms. The Milky Way also contains two significant minor arms, as well as two smaller spurs. One of the spurs, known as the Orion Arm, contains the sun and the solar system. The Orion arm is located between two major arms, Perseus and Sagittarius.
The Milky Way does not sit still, but is constantly rotating. As such, the arms are moving through space. The sun and the solar system travel with them. The solar system travels at an average speed of 515,000 mph (828,000 km/h). Even at this rapid speed, the solar system would take about 230 million years to travel all the way around the Milky Way.
"Spiral arms are like traffic jams in that the gas and stars crowd together and move more slowly in the arms. As material passes through the dense spiral arms, it is compressed and this triggers more star formation," said Camargo.
Our galaxy is surrounded by an enormous halo of hot gas that extends for hundreds of thousands of light-years. The gas halo is estimated to be as massive as all of the stars in the Milky Way. Like the galaxy itself, the halo is spinning rapidly.
This very wide-field view of the Milky Way shows the extent of the 84-million-star VISTA infrared image of the center of the galaxy (delineated by red rectangle).
Credit: ESO/Nick Risinger (skysurvey.org)
"This flies in the face of expectations," Edmund Hodges-Kluck of the University of Michigan said in a statement. "People just assumed that the disk of the Milky Way spins while this enormous reservoir of hot gas is stationary – but that is wrong. This hot gas reservoir is rotating as well, just not quite as fast as the disk."
Curled around the center of the galaxy, the spiral arms contain a high amount of dust and gas. New stars are constantly formed within the arms. These arms are contained in what is called the disk of the galaxy. It is only about 1,000 light-years thick. [Photo Gallery: Stunning Photos of Our Milky Way Galaxy]
At the center of the galaxy is the galactic bulge. The heart of the Milky Way is crammed full of gas, dust, and stars. The bulge is the reason that you can only see a small percentage of the total stars in the galaxy. Dust and gas within it are so thick that you can't even peer into the bulge of the Milky Way, much less see out the other side.
Tucked inside the very center of the galaxy is a monstrous black hole, billions of times as massive as the sun. This supermassive black hole may have started off smaller, but the ample supply of dust and gas allowed it to gorge itself and grow into a giant. The greedy glutton also consumes whatever stars it can get a grip on. Although black holes cannot be directly viewed, scientists can see their gravitational effects as they change and distort the paths of the material around it, or as they fire off jets. Most galaxies are thought to have a black hole in their heart. [Photo Gallery: The Milky Way's Core]
This photo illustration depicts a view of the night sky just before the predicted merger between our Milky Way galaxy and the neighboring Andromeda galaxy. Image released May 31, 2012.
Credit: NASA, ESA, Z. Levay and R. van der Marel (STScI), and A. Mellinger
The bulge and the arms are the most obvious components of the Milky Way, but they are not the only pieces. The galaxy is surrounded by a spherical halo of hot gas, old stars and globular clusters. Although the halo stretches for hundreds of thousands of light-years, it only contains about two percent as many stars as are found within the disk.Scientists can't directly detect the material, but like black holes, they can measure it based on its effect on the objects around it. As such, dark matter is estimated to make up 90 percent of the mass of the galaxy.
Recent measurements have weighed the galaxy at between 400 billion and 780 billion times the mass of the sun. By focusing on how the Milky Way affects its neighboring globular clusters, dense groups of stars smaller than a galaxy, scientists were able to calculate the mass of the Milky Way at varying distances. The result can help them improve their understanding of how much of the galaxy is made up of ordinary material like dust and stars, and how much is composed of dark matter.
"Even though we know the dark matter should be there, [and] we think it should be there, the ratio of dark matter to luminous matter in particular galaxies may be under debate," Gwendolyn Eadie, a Ph.D. candidate in astrophysics at McMasters University in Ontario, Canada, and co-author on the research, told Space.com.
The dark Coalsack is readily apparent in the middle of the image. The stars Alpha Centauri (the closest star to our solar system at 4.3-light years away) and Beta Century are to the left of the Coalsack, while the famous Southern Cross (Crux) is poised just above and to the right of the Coalsack. The Southern Milky Way is far more spectacular than the Milky Way that those of us situated north of the equator can ever see. Taken from La Serena, Chile on April 6, 1986.
Credit: Joe Rao
Milky Way facts
The Milky Way contains over 200 billion stars, and enough dust and gas to make billions more.
The solar system lies about 30,000 light-years from the galactic center, and about 20 light-years above the plane of the galaxy. Earth and its neighbors don't orbit within the plane of the galaxy but are instead tipped by about 63 degrees.
"It's almost like we're sailing through the galaxy sideways," Merav Opher, an astrophysicist at George Mason University in Virginia, told Space.com.
More than half the stars found in the Milky Way are older than the 4.5-billion-year-old sun. Galaxies like ours typically undergo a stellar baby boom, churning out stars in enormous quantities roughly 10 billion years ago.
The most common stars in the galaxy are red dwarfs, a cool star about a tenth the mass of the sun. Once thought unsuitable for potential life-bearing planets because such bodies would have to be too close to meet the criteria, red dwarfs are now considered potential suspects.
As late as the 1920s, astronomers thought all of the stars in the universe were contained inside of the Milky Way. It wasn't until Edwin Hubble discovered a special star known as a Cepheid variable, which allowed him to precisely measure distances, that astronomers realized that the fuzzy patches once classified as nebula were actually separate galaxies.
NASA recently selected the Galactic/Extragalactic ULDB Spectroscopic Terahertz Observatory (GUSTO) mission to fly a telescope carried by balloon to map out large sections in the Milky Way and nearby Large Magellenic Cloud. The mission plans to launch in 2021 from McMurdo, Antarctica and should remain in the air between 100 and 170 days, depending on weather conditions.
The universe en.wikipedia.org/wiki/Universe
The Hubble Ultra-Deep Field image shows some of the most remote galaxies visible with present technology, each consisting of billions of stars. (Apparent image area about 1/79 that of a full moon)[1]
