Post by miket on Jun 18, 2018 9:32:35 GMT -5
Found this on Friday- does anyone have any tips for removing the "brown" coating on the outside of the rock to uncover the fairburn? And does anyone know what that coating is? Attachments:
Post by Pat on Jun 18, 2018 10:00:38 GMT -5
If it is iron, IRON OUT is excellent.
Post by miket on Jun 18, 2018 10:17:02 GMT -5
Yeah, Iron Out is excellent- but is there a way to tell if if it's iron? I guess I could always soak it for a few days and see if it works... Thanks Pat!
Post by vegasjames on Jun 18, 2018 18:46:14 GMT -5
Citric acid or oxalic acid also work great for removing iron costings.
Post by miket on Jun 18, 2018 19:16:17 GMT -5
I'll try that, too. Thanks!
Post by miket on Jun 19, 2018 11:38:06 GMT -5
So I put this one in Iron Out yesterday, haven't seen much change yet. It's worked very well on other rocks that I've collected- but I just bought some Wood Bleach (oxalic acid), and I'm going to give that a shot. Outside, of course! If I get decent results I'll try to post a picture. I'm keeping my eye out for a cheap crock pot that I can use, but for now I'm just going to give it a go.
Post by miket on Jun 22, 2018 16:08:20 GMT -5
Three days in oxalic acid and not much change. I keep making the mixture a little stronger without better results. I took it out, rinsed it well and scrubbed it with a brush- a bit more of the outer "shell" came off, but nothing really noticeable. I guess the next step would be to use a mechanical approach, like a dremel. I just want a peek! Stubborn rock.
Thunder69
Thunder 2000-2015
Post by Thunder69 on Jun 22, 2018 20:02:28 GMT -5
The outer shell is solid rock ..the only way to see more pattern is to grind the shell off...
Post by miket on Jun 22, 2018 23:04:42 GMT -5
It would sure seem so. I was hoping it was iron...
