Post by sophia13 on Jul 3, 2018 7:49:47 GMT -5
I need to get the belt off my motor and arbor from my 8" Raytech Gemmaker the proper way so I can put some new wheels on and clean it up. Anyone know where a video or tutorial is or would care to advise on how to do that would be wonderful. Please and thank you …..I searched You tube and on here to no avail.
Post by manofglass on Jul 3, 2018 10:45:48 GMT -5
Post photos of it
Post by sophia13 on Jul 3, 2018 11:11:17 GMT -5
Post by manofglass on Jul 3, 2018 11:36:00 GMT -5
I don’t own one start by taking the buffing wheels Off they should unscrew then take the nuts And washers off that hold the wheels on Pull the expandos then more photos
Post by catmandewe on Jul 4, 2018 10:33:41 GMT -5
Take the belt guard off, then take the housing bolts out of the top (2 black handles on top of the unit), you will have to slip the belt off of the pulley on the motor and then the top housing should be hinged so that it all folds back so you can remove the whole arbor as one piece. This was a slick design, wish more companies would have used it.
Tony
Post by catmandewe on Jul 4, 2018 10:35:44 GMT -5
PS- You might not have to completely remove the belt guard if you can slip the belt off the pulley through the trap door in the top of the housing. A screwdriver will usually be sufficient, watch your fingers, getting them caught between the belt and the pulley can remove pieces of them.
Post by Fossilman on Jul 4, 2018 13:48:03 GMT -5
Yuppers, just like the one I have... Been lucky so far, no replacing parts yet....
Post by sophia13 on Jul 5, 2018 12:17:28 GMT -5
Yuppers, just like the one I have... Been lucky so far, no replacing parts yet.... Thanks guys, I'll try suggestions
Post by johnjsgems on Jul 5, 2018 14:03:56 GMT -5
What Tony said. To remove the grinding wheels you will have to remove at least one bearing.
