nchillbilly
Member since January 2018
Post by nchillbilly on Jul 8, 2018 22:49:38 GMT -5
I have had a thumler's tumbler model B for a number of years. In the past , I've only used it with stainless steel pins to clean brass ammunition cases. Well, I found myself with 10 lbs of Rhyolite (sourced from vegasjames) that needed tumbled, so I decided to use the "B". My question is: is there any difference in the set-up, machine-wise, for tumbling rocks versus brass? The "B" turns a good bit faster than my lortone qt6. The speed doesn't bother me as long as it's not detrimental to the rocks.
pizzano
Member since February 2018
Post by pizzano on Jul 9, 2018 17:45:24 GMT -5
If memory serves.....your Thumler barrel should run at about 38rpm's with 8lb to10lb's of load. That is if it isn't the "high speed" version....which is rated at a higher speed motor......don't know the expected barrel rate with same load poundage.
All my "little" rollers run btw 38 and 44 rpms......don't see a reason to be concerned with the model B. Try it with a full load of "toss-a-sides".......nothing lost - something gained if it handles the stone media. As you know, I only use my rollers for rough grind anymore......it may just work great for 1st-2nd cycle grinding.
Give it a try.........since I switched to vibe's......no more casings in the rollers for me.......lol.
Post by jamesp on Jul 10, 2018 4:53:25 GMT -5
If this helps A 60% filled barrel at 30 RPM will beat you rocks up more so than a an 85% filled barrel at 80 RPM. Chunk gravel in your barrel at 60% and then at 85%, add water as normal say just below rock level and roll. Compare noise. One fill is gentle and the other violent.
nchillbilly
Post by nchillbilly on Jul 10, 2018 16:48:42 GMT -5
Give it a try.........since I switched to vibe's......no more casings in the rollers for me.......lol. I still do a final polish of my ammo cases in a vibe, but if you've never used stainless steel pins, lemi-shine, and dawn in a rotary to do the initial clean, you'd be amazed at how they come out. Knock the spent primers out and resize them first, toss 'em in the mix in a roller for a couple of hours and they come out looking brand new. As far as the rocks, I pretty much use rotaries for my heavy grit runs also. Anything up to 60/90 sic. After that, they go in the vibe.
nchillbilly
Post by nchillbilly on Jul 10, 2018 16:57:21 GMT -5
If this helps A 60% filled barrel at 30 RPM will beat you rocks up more so than a an 85% filled barrel at 80 RPM. Chunk gravel in your barrel at 60% and then at 85%, add water as normal say just below rock level and roll. Compare noise. One fill is gentle and the other violent. My current batch is probably 80% +. I've never used this tumbler for rocks, so it's probably just a matter of me getting used to it. I was just curious since it is running right beside my lortone, and there is a noticeable difference in speed. The stone in there is very interesting looking, so I don't want to beat them to death. I'll clean out this weekend, so I'll find out then how they're doing.
Post by jamesp on Jul 11, 2018 2:15:56 GMT -5
If this helps A 60% filled barrel at 30 RPM will beat you rocks up more so than a an 85% filled barrel at 80 RPM. Chunk gravel in your barrel at 60% and then at 85%, add water as normal say just below rock level and roll. Compare noise. One fill is gentle and the other violent. My current batch is probably 80% +. I've never used this tumbler for rocks, so it's probably just a matter of me getting used to it. I was just curious since it is running right beside my lortone, and there is a noticeable difference in speed. The stone in there is very interesting looking, so I don't want to beat them to death. I'll clean out this weekend, so I'll find out then how they're doing. Good luck with the rhyolite. It is beautiful.
