Post by fernwood on Jul 22, 2018 5:57:51 GMT -5
Received this matched set to make a pair of earrings. Trying to determine the best approach. The whorl end is a little over 1/8” thick. Would it be best to take my chances and drill a hole in the end for an eye up? Any other suggestions? I still do not have soldering supplies. Prefer not to glue on modified end caps. I am concerned about achieving the correct balance with these. Also, wondering if I should leave the reverse side as is, or try smoothing/polishing it? Do not want to lose the iridescence or details, but both are a little rough in places. Thank you. shells 1 shells 2 shells 3
Post by Fossilman on Jul 22, 2018 7:56:41 GMT -5
Have to remember also, that these where a living creature and are very fragile... Make sure your diamond bits are very sharp, or they will fracture... Good luck..
Post by fernwood on Jul 22, 2018 8:06:56 GMT -5
Agree, which is why I was a little concerned about drilling the holes. Have some never used diamond bits, so will muster up the courage to try.
Post by hummingbirdstones on Jul 22, 2018 9:13:07 GMT -5
Is it possible to get another ammonite to test drill on to see how it goes? The non-iridescent ones should be relatively inexpensive or maybe someone has a broken one that could be donated to the cause?
I've never drilled one, so am wondering just how fragile it might be.
