Post by wigglinrocks on Jul 25, 2018 13:48:47 GMT -5
I've been using this method for polishing cabs and slabs in a vibe with very good results . I put in the recommended amount of borax , then add 3 drops of Dawn dish soap and get it moving for a few minutes . As you can see it gets pretty foamy , so don't overdo it with the Dawn . Then I add the polish to the load and keep an eye on it for a couple hours to make sure it isn't overflowing with foam . I use small and big ceramics for cushion and hauling the polish around . Since adding Dawn and foam , I don't have problems with slabs sticking and staying together . And I see a film of polish spread across the slab when they are moving around in there . Works good with all the grit cycles also and I get uniform grinds and polish . Different vibes will surely take different amounts . The one in the pic is a Gy Roc model A , in my model B I only use a drop or two of Dawn . I just started this load a few hours ago , if I get a chance tomorrow I update this and show the results . Thanks for your time .
Post by victor1941 on Jul 25, 2018 13:56:47 GMT -5
This looks like a good mix of media and material. Does this unit have a top?
Post by grumpybill on Jul 25, 2018 15:33:32 GMT -5
I add a little water when I notice slices sticking together in my Lot-O. Gonna' try using some Dawn in the next batch.
Post by TheRock on Jul 25, 2018 20:00:25 GMT -5
Good Info?
Post by wigglinrocks on Jul 25, 2018 20:05:45 GMT -5
This looks like a good mix of media and material. Does this unit have a top? Yeah it does have a lid , took it off to get a photo .
Post by wigglinrocks on Jul 25, 2018 20:10:27 GMT -5
I add a little water when I notice slices sticking together in my Lot-O. Gonna' try using some Dawn in the next batch. This method seems to work a bit better than just running wetter loads . The grit or polish floats all over with the foam . If ya try it , be careful not to add too much soap . One extra drop will make an uh oh real fast .
Post by wigglinrocks on Jul 25, 2018 20:12:46 GMT -5
Good Info? There is a method to my madness . Just need to work on more method than madness .
Post by grumpybill on Jul 25, 2018 20:30:15 GMT -5
If ya try it , be careful not to add too much soap . One extra drop will make an uh oh real fast . Been there; done that. (I run extra water and Dawn for 20 - 30 minutes at the end of cycles to help with cleaning the stones.)
Post by wigglinrocks on Jul 25, 2018 21:02:07 GMT -5
Been there; done that. (I run extra water and Dawn for 20 - 30 minutes at the end of cycles to help with cleaning the stones.) Had a few foam overloads myself . Try to get a drop or two but the bottle has other plans . I do the same pre rinse cleaning and a post rinse wash cycle , only a few minutes each though .
