Post by vegasjames on Jul 30, 2018 23:27:28 GMT -5
Post by fernwood on Jul 31, 2018 5:00:16 GMT -5
Those are some serious agates. Thanks for sharing.
Post by fantastic5 on Jul 31, 2018 6:56:18 GMT -5
Thanks for the link vegasjames. Has anyone seen an enhydro agate? I've found enhydro quartz crystals before, but I would think the agate would be harder to identify unless it was really clear.
Post by vegasjames on Jul 31, 2018 7:28:49 GMT -5
Thanks for the link vegasjames . Has anyone seen an enhydro agate? I've found enhydro quartz crystals before, but I would think the agate would be harder to identify unless it was really clear. There are some examples on YouTube like this one:
Post by rockjunquie on Jul 31, 2018 8:10:43 GMT -5
Thanks for the link! Besides being educational, it is delicious eye candy.
kskid
Member since July 2014
Post by kskid on Jul 31, 2018 23:57:14 GMT -5
Forgive me for straying from the OP, but did someone know what that was before they cut it or were they just doggone lucky they cut it where they did?
Post by Deleted on Aug 1, 2018 2:37:44 GMT -5
Forgive me for straying from the OP, but did someone know what that was before they cut it or were they just doggone lucky they cut it where they did? You can sometimes shake nodules that have large, partially filled voids and tell that it contains some water (sort of like shaking a coconut). Sometimes, they feel lighter, too. If they suspected a water-filled central chamber, then they'd avoid cutting through the center, where the enhydro would most likely reside. Smaller pieces or pieces with smaller voids, one just has to keep a sharp eye out. Even then, one can always saw (or grind) right through a wall or connected fissure, allowing the water to spill out.
kskid
Post by kskid on Aug 2, 2018 22:00:47 GMT -5
Very cool. Thank you for the info @rocks2dust !
Post by pauls on Aug 3, 2018 1:46:36 GMT -5
NRG
Member since February 2018
Post by NRG on Aug 5, 2018 16:25:56 GMT -5
Thanks for the link vegasjames. Has anyone seen an enhydro agate? I've found enhydro quartz crystals before, but I would think the agate would be harder to identify unless it was really clear. Agate forms at higher temperature than quartz. So free water will be rarer.
