NRG
Member since February 2018
Post by NRG on Oct 5, 2018 16:48:39 GMT -5
NRG
Post by NRG on Oct 5, 2018 16:49:11 GMT -5
Found this while researching HxTal that all y'all been researching.
Post by MsAli on Oct 5, 2018 16:58:13 GMT -5
Post by Deleted on Oct 5, 2018 17:22:37 GMT -5
Most interesting use of dichroic glass I've yet seen.
Post by Pat on Oct 5, 2018 18:14:27 GMT -5
Woooooow!
I could watch that for a long time. Thanks!
NRG
Post by NRG on Oct 5, 2018 18:28:13 GMT -5
Woooooow!I could watch that for a long time. Thanks! His videos are about 1.5 minutes. I have at least 3 hours in watching them. He had one explode last year and lost vision in one eye. Now he makes the dichroic part and has them faceted for jewelry.
Post by jamesp on Oct 5, 2018 20:54:14 GMT -5
That fellow is an amazing glass artist.
NRG
Post by NRG on Oct 5, 2018 21:40:26 GMT -5
That fellow is an amazing glass artist. Cold formed. Glued up. Sliced. Polished. Restacked. Sliced polished, restacked..... It's just lead crystal and dichroic glass and HxTal glue
Post by hummingbirdstones on Oct 5, 2018 23:33:55 GMT -5
What a talent and imagination. Gorgeous stuff!
Post by jamesp on Oct 6, 2018 7:48:38 GMT -5
That fellow is an amazing glass artist. Cold formed. Glued up. Sliced. Polished. Restacked. Sliced polished, restacked..... It's just lead crystal and dichroic glass and HxTal glue He is a serious machine head, his machine shop is salvaged and used stuff. Lot of it HD metal working machinery converted for glass sawing/grinding/polishing. The beauty of working glass is that is soft and cuts/polishes fast. And it can be glued together about as strong as it can me fused together with zero bubbles at the bond. This fellow took these principles to the extremes. I thought he used super glue but it is HxTal, an epoxy ? Bet he would cringe at the thought of using my glass that is full of bubbles lol. Only the finest lead crystal highly refined in his shop. Plus he doesn't have to worry about well annealed glass or incompatible fusions which would set him free to do what he does. I love the melt factor, the color mixing, and glass has one of the best abilities of any material to carry color. But he gets to play with the optical qualities and colors and refractions on a much more sophisticated level. I know of no one else like him.
NRG
Post by NRG on Oct 6, 2018 11:16:46 GMT -5
jamespHxTal is an epoxy. Yes. It's a very interesting material to me. One week cure, to 90% of full strength. Not even finished at a week. Has the highest non-yellowing rating amongst epoxies. Very low catalyst rate, makes a slow cure and water white product. Bubbles removed in avacuum chamber. I have a 5 gallon vac chamber. Your observation that he uses metal working gear makes sense. He makes the most perfect cubes and sphere preforms I have ever seen. That's a combination of gear and skill no doubt.
Post by jamesp on Oct 7, 2018 8:06:33 GMT -5
jamespHxTal is an epoxy. Yes. It's a very interesting material to me. One week cure, to 90% of full strength. Not even finished at a week. Has the highest non-yellowing rating amongst epoxies. Very low catalyst rate, makes a slow cure and water white product. Bubbles removed in avacuum chamber. I have a 5 gallon vac chamber. Your observation that he uses metal working gear makes sense. He makes the most perfect cubes and sphere preforms I have ever seen. That's a combination of gear and skill no doubt. His shop looks just like a machine shop for working metal. Those machines are super precision as you well know. A Bridgeport mill, dead accurate for example. Usually the slower the epoxy takes to dry the stronger it is. The fast dry agents weaken it. Seems like I heard 1 hour epoxy is order of magnitude stronger than 5 minute.
NRG
Post by NRG on Oct 7, 2018 10:21:24 GMT -5
NRG
Post by NRG on Oct 7, 2018 10:22:29 GMT -5
mossyrockhound
Member since January 2011
Post by mossyrockhound on Oct 7, 2018 22:04:50 GMT -5
Absolutely beautiful piece! True craftsmanship. Thanks for posting.
Post by Rockoonz on Oct 8, 2018 2:04:24 GMT -5
Big laps made from tires, too cool.
NRG
Post by NRG on Oct 9, 2018 19:21:14 GMT -5
Big laps made from tires, too cool. Those are commercial too! www.hisglassworks.com sells two makers of this style of lap.
