mikeinsjc
Member since June 2010
Post by mikeinsjc on Nov 6, 2018 10:56:41 GMT -5
Much of the petrified wood from Montana is as black as coal on the inside. It is kind of deceptive, because on the outside water has bleached the whatever out of the rocks surface and you think it is going to be pretty cool inside. They are filthy to cut. The saw oil turns black, the inside of the saw turns black, so I try to wait to cut them until I am ready to change the saw oil.
After I polish the black slabs (sounds like the name for a rock group) I put them in straight bleach for 3-4 days. Wow, what a difference! I would like to post a picture on here but find the procedure too cumbersome for someone that still uses a Razr phone.
Anyway, does anyone have any idea what the bleach is doing chemically? The bleach is not discolored after 4 days so it appears nothing is being removed from the slab, just altered.
PS where is the "attach file" mentioned in the pict upload tutorial? I click "upload file" and nothing seems to happen. Man I hate computers.
bsky4463
Member since September 2013
Post by bsky4463 on Nov 6, 2018 11:44:52 GMT -5
Hey Mike - I too have bleached petwood collected here in MT. It seems to work very well on wood that has gone thru a carbonization process and doesnt do anything to material that has been silicated. But sorry I do not know specifically the answer to your question. As you probably already know it just affects the surface of the stone and does not seem to penetrate. Hence I have found it most effective to do it after the grinding and sanding steps but before final polish. Cheers
Post by parfive on Nov 6, 2018 12:49:49 GMT -5
PS where is the "attach file" mentioned in the pict upload tutorial? I click "upload file" and nothing seems to happen. Man I hate computers. I couldn’t find it either a while back. I think that option was disappeared when Cloudy showed up, and it just hasn’t been edited out of the tute. Tommy ?
Post by woodman on Nov 6, 2018 13:34:43 GMT -5
You can do the same thing by leaving it lay out in the sun after finial polish. Just takes longer.
Post by Deleted on Nov 6, 2018 14:17:25 GMT -5
PS where is the "attach file" mentioned in the pict upload tutorial? I click "upload file" and nothing seems to happen. Man I hate computers. What browser are you using? The "Upload File" button should give you a pop-up window into which you can drag the image file or click a button to select it. You have to sign up for Cloudinary before it works, though (see this thread).
mikeinsjc
Post by mikeinsjc on Nov 6, 2018 16:11:09 GMT -5
bsky, I do the bleach after final polish- doesn't seem to make any difference, and the piece still takes a nice polish. I do notice that this wood seems to absorb oil during cutting like a lot of wood does, but the black stuff seems to take in more than others. It seems to clog the bull wheel belts more also.
Post by oregon on Nov 6, 2018 16:21:06 GMT -5
I offered to post Mike's pics because there is truckloads of 'charcoal' petrified wood here in Oregon as well - never tried bleaching, but might have to. before and after with the same material mikeinsjc
bsky4463
Post by bsky4463 on Nov 6, 2018 16:38:56 GMT -5
bsky, I do the bleach after final polish- doesn't seem to make any difference, and the piece still takes a nice polish. I do notice that this wood seems to absorb oil during cutting like a lot of wood does, but the black stuff seems to take in more than others. It seems to clog the bull wheel belts more also. Mike - agreed before or after polish it works...probably even better after polish. I think because the material is not silicated, it is more pourous and absorbs the oil. I think the gunk on the bull-wheel maybe oil residue. Do you heat the specimens to drive out the oil after you cut?
mikeinsjc
Post by mikeinsjc on Nov 6, 2018 17:19:25 GMT -5
bsky, I have not baked them. It has to be done outside,my friend says, as it really stinks. I figured if baking (my fiend only sets oven at 150)works, so would boiling them in a pot of water on the stove. Glad my wife wasn't home- it really stinks that way too.
I have found some work-arounds that still enable me to get a nice polish. One thing that seems to help- but it may be my imagination- it to wipe the slab with acetone immediately before the bull wheel.
bsky4463
Post by bsky4463 on Nov 6, 2018 18:15:33 GMT -5
mikeinsjc ayup low temp it oozes out. A cheap way to go is an old BBQ, just light one burner on low (low-low) and then offset the pieces on the grill so it is indirect heat. Not a good ID to bake out oil in anything that will used for food consumption IMO..... Tom Yard who builds the Ultimate Grinder (bull wheel) was adamant about getting the oil out to get the best possible shine. He has a cool vacuum oven for this purpose...someday I shall find one! Another no bake option is soaking in TSP cleaner. I scrub with Simple Green or similar de-greaser and then a 1/4-1/3 cup of TSP per gallon of water and soak them over night and then scrub again with de-greaser... I actually do this with all my slabs before I cab or sell them. Works on wood specimens too, just not as good as baking.
Post by RWA3006 on Nov 6, 2018 22:13:19 GMT -5
Are you guys using plain old bleach, hydrogen peroxide, or something else?
Post by woodman on Nov 6, 2018 22:52:32 GMT -5
mikeinsjc ayup low temp it oozes out. A cheap way to go is an old BBQ, just light one burner on low (low-low) and then offset the pieces on the grill so it is indirect heat. Not a good ID to bake out oil in anything that will used for food consumption IMO..... Tom Yard who builds the Ultimate Grinder (bull wheel) was adamant about getting the oil out to get the best possible shine. He has a cool vacuum oven for this purpose...someday I shall find one! Another no bake option is soaking in TSP cleaner. I scrub with Simple Green or similar de-greaser and then a 1/4-1/3 cup of TSP per gallon of water and soak them over night and then scrub again with de-greaser... I actually do this with all my slabs before I cab or sell them. Works on wood specimens too, just not as good as baking. Sometime i use a degreaser before baking in an oven in my open tractor shed, I picked up a cheap kitchen stove for just that purpose, for small stuff I have a toaster oven I got a goodwill. The oil MUST come out before any other work is done. At least that is what I think!
Post by Drummond Island Rocks on Nov 7, 2018 11:29:39 GMT -5
I do not work with pet wood much but after reading the last few posts I think my bowling ball oven is the ideal tool for removing the oil from the slabs. It has heat settings from 125-175 and is made to remove lane oil out of bowling balls. It has a reservoir to hold the oil that drips off. These are basically re-purposed food dehydrators at an inflated price. This is the oil coming out of one my kids bowling balls. And this is the oil in the tray when done Chuck
mikeinsjc
Post by mikeinsjc on Nov 7, 2018 12:22:54 GMT -5
rwa3006, I use Clorox germicidal bleach from Lowes, about $4-5/gallon
Drummond, that looks like the perfect thing to treat the slabs. Are those things expensive?
Post by Drummond Island Rocks on Nov 7, 2018 12:30:25 GMT -5
rwa3006, I use Clorox germicidal bleach from Lowes, about $4-5/gallon Drummond, that looks like the perfect thing to treat the slabs. Are those things expensive? Yeah they are overpriced because there is a limited market and they have to pay off there tooling. I think I paid about $200 for that one. The company uses the lid and heating element from a food dehydrator and just makes a new base and case to hold the bowling ball. I am sure the dehydrators are cheaper and would work as good or better for slabs. This is same heating unit on a dehydrator for 1/4 the price. I noticed the temps says 95 to 155 so I may have been wrong in my earlier post. www.amazon.com/Nesco-FD-60-Snackmaster-Express-Dehydrator/dp/B000LNVUJQChuck
Post by Deleted on Nov 7, 2018 12:59:03 GMT -5
Are you guys using plain old bleach, hydrogen peroxide, or something else? I've used both, but prefer oxygen bleach (aka, Oxi-Clean and similar powdered oxygen bleaches) from the laundry aisle in any grocery store. There is a stronger version sold as Wood Bleach (peroxide bleach + oxalic acid) sold in home improvement stores. There are some oxygen bleaches marketed specifically to rockhounds, though I haven't tried that. Takes longer, but no nasty fumes and less etching on some materials. Agree with sunlight as an even milder option. For any bleaching, you have to live with giving up some of the more intense colors: particularly rich reds, greens, blues and red-browns. I even like the black in some (much better than gray that would result from some harsh bleaching. When just featureless black, bleaching can certainly improve, but I wouldn't bleach only because it turns your oil black (that can be filtered and re-used). As was said, you'd bleach only after you've cut, anyway.
Post by pauls on Nov 7, 2018 16:42:25 GMT -5
This is interesting, some of the black petrified wood I have found gives off a very organic bitumen smell when cutting, I will have to try this. Different wood, different continent even, and silicified and hard but worth a try.
Post by woodman on Nov 24, 2018 21:22:54 GMT -5
This a small slab that I bleached by leaving it out in the sun, it was out for along time maybe a year, I lost track of the time.
Post by greig on Nov 25, 2018 12:06:55 GMT -5
