Post by fernwood on Dec 27, 2018 16:05:56 GMT -5
These have been running for 10 weeks in SIC 60. 3 lb rotary barrel. Used 3 TBS grit, 4 TBS used slurry and topped off with water to just below rocks. During clean out today, I noticed there had been little change. The grit had not broken down at all. The slurry looked a little thick. 1st set of photos is what I put in. 2nd and 3rd what I took out today. They are now running in Borax. These were all self collected on my land. Any thoughts?
fishnpinball
So much to learn, so little time
Member since March 2017
Post by fishnpinball on Dec 27, 2018 16:26:43 GMT -5
Might have overfilled it a little?
Post by fernwood on Dec 27, 2018 16:48:55 GMT -5
Dunno. Was 3/4 full as usual.
Post by MsAli on Dec 27, 2018 17:39:20 GMT -5
One thing you might want to check is your rotation speed.
I noticed when my belt was too loose the barrel rotated slower, I wasn't getting good results and the grit wasn't breaking down.
Once I replaced my belt things are turning nicely in there
Post by miket on Dec 27, 2018 18:16:02 GMT -5
Ali might be right. I had to tighten the belt on my 33b and now it runs like a champ.
goldminer
Member since March 2018
Post by goldminer on Dec 27, 2018 20:29:00 GMT -5
These stones to me look like many are too large for a 3lb. tumbler. Are you using ceramic media and are the stones similar in hardness?
goldminer
Post by goldminer on Dec 27, 2018 20:42:26 GMT -5
Nice looking stone though!
Post by gmitch067 on Dec 27, 2018 22:31:53 GMT -5
fernwoodSiC 60/90 is probably the coarsest grit I would run in a 3 lb. rotary. If you are using graded 60 grit, I would expect the grind to be less effective. Still... after 10 weeks you should be seeing more of a grind. Your filling the tumbler to 3/4 full seems adequate, and the addition grit and slurry sounds good. I think I would agree with what MsAli suggested... check the belt tension and tighten/replace it.
Mark K
Member since April 2012
Post by Mark K on Dec 27, 2018 22:43:59 GMT -5
The problem is the rocks. You see, those came from a mine the Chinese took over. It was run by a real screw up named Sum Ting Wong. Happens every time.
fishnpinball
Post by fishnpinball on Dec 27, 2018 23:40:40 GMT -5
Looking at the rocks there is a possibility the rocks jammed up and didn't tumble correctly because they mostly moved as one mass.
Post by fernwood on Dec 28, 2018 0:23:26 GMT -5
Thanks everyone. Will check belt tension or RPM's. The largest rock in the load is about 1 3/4". The barrel "sounded" like everything was moving fine. The mix is jaspers, agates, quartz, fossils and granite. Most of the granite is shaping up nicely.
Will look at everything closer on New Years as that is the next day I am not working. '
