Post by Jugglerguy on Jan 6, 2019 17:19:19 GMT -5
I have no idea how to read a wiring diagram. Could someone please tell me where to hook up my cord? I don’t care which way the motor turns. Thanks.
Post by pauls on Jan 6, 2019 20:23:44 GMT -5
The ones marked line are your cord, earth wire goes under that blue coloured screw on the case of the motor.
So one goes under the terminal with the blue wire the other goes under the terminal slightly to the left of the blue earth screw.
That diagram is an actual picture of the layout.
Post by Jugglerguy on Jan 6, 2019 20:26:07 GMT -5
The ones marked line are your cord, earth wire goes under that blue coloured screw on the case of the motor. Does it matter if I switch around the two line wires?
Post by pauls on Jan 6, 2019 20:29:41 GMT -5
The ones marked line are your cord, earth wire goes under that blue coloured screw on the case of the motor. Does it matter if I switch around the two line wires? No, It's AC.
Post by Jugglerguy on Jan 6, 2019 20:35:42 GMT -5
Does it matter if I switch around the two line wires? No, It's AC. Ok, thanks.
Post by RWA3006 on Jan 6, 2019 20:53:54 GMT -5
The ones marked line are your cord, earth wire goes under that blue coloured screw on the case of the motor. So one goes under the terminal with the blue wire the other goes under the terminal slightly to the left of the blue earth screw. That diagram is an actual picture of the layout. Just a little clarification ... What he called "blue earth screw" is bluish in the photo, but in living color it will be green. Also, what he is referring to by "earth" we would call "ground" here in the states. Just saying...
Post by pauls on Jan 6, 2019 21:17:30 GMT -5
Thanks for that rwa, Earth and ground are mostly interchangeable here, I wondered about the colour of the screw but just went with what I saw, it would be green here too.
Post by Jugglerguy on Jan 6, 2019 21:56:07 GMT -5
The ones marked line are your cord, earth wire goes under that blue coloured screw on the case of the motor. So one goes under the terminal with the blue wire the other goes under the terminal slightly to the left of the blue earth screw. That diagram is an actual picture of the layout. Just a little clarification ... What he called "blue earth screw" is bluish in the photo, but in living color it will be green. Also, what he is referring to by "earth" we would call "ground" here in the states. Just saying... Thanks. That was the one wire I understood before asking. It’s all wired up and works fine.
Post by johnjsgems on Jan 7, 2019 20:37:43 GMT -5
Some motors will say "common" on one terminal. Or "grounded terminal". It works either way but best to connect white (neutral) wire there. Most common motors have red and black wires to change rotation but that doesn't matter either. Some foreign to US cords use different colors as well but just keep the neutral and hot leads connected properly.
Post by Jugglerguy on Jan 8, 2019 8:32:30 GMT -5
Some motors will say "common" on one terminal. Or "grounded terminal". It works either way but best to connect white (neutral) wire there. Most common motors have red and black wires to change rotation but that doesn't matter either. Some foreign to US cords use different colors as well but just keep the neutral and hot leads connected properly. Thanks John. I’ll open it back up and see if I can find either of those words.
Post by parfive on Jan 8, 2019 11:41:23 GMT -5
Some motors will say "common" on one terminal. Or "grounded terminal". It works either way but best to connect white (neutral) wire there. Most common motors have red and black wires to change rotation but that doesn't matter either. Some foreign to US cords use different colors as well but just keep the neutral and hot leads connected properly. Thanks John. I’ll open it back up and see if I can find either of those words. Why not just scroll up and look at the pics? : )
Post by Jugglerguy on Jan 8, 2019 12:03:20 GMT -5
Thanks John. I’ll open it back up and see if I can find either of those words. Why not just scroll up and look at the pics? : ) Surprisingly, I thought of that. I just couldn't find those words in the pics. I thought it might be easier to see if I moved my head and the flashlight around to see behind the wires.
Post by parfive on Jan 8, 2019 12:25:59 GMT -5
Look on the wiring diagram, at the two terminals where the LINE—aka your cord—is connected.
Your black wire should go on the terminal marked L
Your white wire should go on the terminal marked C, or common
Post by Jugglerguy on Jan 8, 2019 20:12:57 GMT -5
Look on the wiring diagram, at the two terminals where the LINE—aka your cord—is connected. Your black wire should go on the terminal marked L Your white wire should go on the terminal marked C, or common I was looking for the whole word. I haven’t opened it up yet, so thanks for the help. I did mention I was clueless on this subject, right?
lookatthat
Member since May 2017
Post by lookatthat on Jan 8, 2019 22:04:26 GMT -5
You're going to wire this? Awfully heavy, but to each his own, I guess. I recommend a simple copper bezel instead. What are you going to use for a bail?
