Post by rockjunquie on May 15, 2019 20:56:55 GMT -5
Those of you who have the intarsia grinder- Rockoonz and Pat and whomever else. I want to get some new grinding discs. What can I use with it that I can purchase like at Kinsley North? What are they called? Backers and laps?
Post by Pat on May 15, 2019 21:07:02 GMT -5
Tela, a friend just rigged up a system of flat lap discs on magnetic discs and uses them on the right side of his Genie —- perpendicular to the wheels. It’s his version of the intarsia grinder.
I don’t know which grits he uses, but imagine it depends on the rocks he is modifying. Good luck!
Post by rockjunquie on May 15, 2019 21:18:36 GMT -5
Tela, a friend just rigged up a system of flat lap discs on magnetic discs and uses them on the right side of his Genie —- perpendicular to the wheels. It’s his version of the intarsia grinder. I don’t know which grits he uses, but imagine it depends on the rocks he is modifying. Good luck! Thanks, Pat. I use spin on discs for polishing on the right, But I could do as you suggest for the left side. I want it for doing backs. So, maybe 280, 600, 1200. Something like that. I was asking because I do have the intarsia grinder. I'm liking your friend's idea, too.
Post by Pat on May 15, 2019 21:33:50 GMT -5
He didn’t like the intarsia grinder because it was too much trouble to keep changing discs on it. I agree, so I use my flat lap a lot with it.
Post by rockjunquie on May 15, 2019 21:56:15 GMT -5
He didn’t like the intarsia grinder because it was too much trouble to keep changing discs on it. I agree, so I use my flat lap a lot with it. It has it's uses. But, just for flat lapping backs- it's a hassle to clean, for me.
Post by Rockoonz on May 16, 2019 7:43:27 GMT -5
Post by rockjunquie on May 16, 2019 7:51:04 GMT -5
