julieooly
Post by julieooly on May 18, 2019 17:44:06 GMT -5
Well, I did it again. Ruined a great looking piece of material with my black sharpie. It's only happened once before with a very very similar piece of Peach Lace Agate. This is Manhattan Lace and was shaping up to be a gorgeous cab.
Post by mohs on May 18, 2019 17:50:40 GMT -5
the pen is not mightier than the rock and that rock is pretty mighty fine
edmohs
Post by Pat on May 18, 2019 17:53:53 GMT -5
You could easily convince me that the marked area is actually part of the rock.
Don’t cry!! It’s lovely!
Post by rockjunquie on May 18, 2019 18:41:14 GMT -5
Does soaking in acetone help?
Post by Deleted on May 18, 2019 22:10:03 GMT -5
Fill your waterpik up with goof-off, ( great x-mas gift for smokers) Lol
Post by taylor on May 18, 2019 23:20:14 GMT -5
after a similar calamity I switched to a silver sharpie, much easier to remove
Post by fernwood on May 19, 2019 5:47:34 GMT -5
I agree with Pat. It does look like part of the pattern.
julieooly
Post by julieooly on May 19, 2019 7:20:15 GMT -5
I intend to try the acetone, but goof off? I love the way it smells at least! I also switched to a gold sharpie but the oil in the rock saw washed it off so I switched back. Thanks to Tela I now have water in my saw. I made the switch and love it!
Post by hummingbirdstones on May 19, 2019 10:12:52 GMT -5
I use a really soft lead pencil on stuff that is porous and totally avoid that problem. It's a little harder to see, but water doesn't seem to wash it off much.
Post by rockjunquie on May 19, 2019 10:29:22 GMT -5
I intend to try the acetone, but goof off? I love the way it smells at least! I also switched to a gold sharpie but the oil in the rock saw washed it off so I switched back. Thanks to Tela I now have water in my saw. I made the switch and love it! Did you get the additive?
julieooly
Post by julieooly on May 19, 2019 11:56:15 GMT -5
I had Tool Cool and am using 2oz to one quart. Should I still drain or after each use? He said to keep an eye out for the beginnings of corrosion. All input welcome.
Post by rockjunquie on May 19, 2019 12:14:00 GMT -5
I had Tool Cool and am using 2oz to one quart. Should I still drain or after each use? He said to keep an eye out for the beginnings of corrosion. All input welcome. I think the point to using the additive is that it is a rust inhibitor and you can leave it in. I just bought some Smokey's EZ Cut for my new rock rascal. ezcut.us/trim-saw-size-16-oz-bottle/
julieooly
Post by julieooly on May 19, 2019 13:36:13 GMT -5
I had Tool Cool and am using 2oz to one quart. Should I still drain or after each use? He said to keep an eye out for the beginnings of corrosion. All input welcome. I think the point to using the additive is that it is a rust inhibitor and you can leave it in. I just bought some Smokey's EZ Cut for my new rock rascal. ezcut.us/trim-saw-size-16-oz-bottle/Does it stink at all? I'm one of those hyper sensitive odor people, seriously I can smell anything! I should capitalize on it somehow
Post by rockjunquie on May 19, 2019 14:40:50 GMT -5
I think the point to using the additive is that it is a rust inhibitor and you can leave it in. I just bought some Smokey's EZ Cut for my new rock rascal. ezcut.us/trim-saw-size-16-oz-bottle/Does it stink at all? I'm one of those hyper sensitive odor people, seriously I can smell anything! I should capitalize on it somehow I'll let you know. I haven't got it, yet.
Post by TheRock on May 19, 2019 15:49:02 GMT -5
Maybe my Vinyl Stickers may be good for something.
