jasonshort
Member since June 2019
Post by jasonshort on Jul 20, 2019 9:44:40 GMT -5
I used 120/220 as step 1. It seems to make a mess in my barrol. I tumbled 1/2 inch and smaller ocean rocks with a mix of ceramic media. For the TV5 owners out there, is this the correct grit to use as the first stage in a vib tumbler or should I start with 220 grit instead? Just learning so all help is much appreciated.
agatemaggot
Member since August 2006
Post by agatemaggot on Jul 20, 2019 11:33:05 GMT -5
From the look of things, I would say the gunk in your tub is the rock snot from the grinding your doing. I suspect your first stage worked well, don't fix it ! If you are not happy with some stones , pick them out and run with the next batch of stage one. If you do (NOT) have sludge in the tub, ------- then something is wrong !
jasonshort
Post by jasonshort on Jul 20, 2019 11:42:43 GMT -5
Thanks for the advise. In your opinion is 120/220 ok to run in a vib tumbler?
