Rockshund
Member since July 2019
Post by Rockshund on Aug 5, 2019 9:12:19 GMT -5
I am new to this forum. Hoping to learn a lot from all of you. I am building a small (up to 3") sphere machine. Starting in rock tumbling also. Question: My little 3-pound Thumbler AR-1 tumbler barrel leaks a little at the lid and recently the lid came off and spilled my batch on the floor. Does anyone know of a better design that will fit this machine? Regards
stonemon
Member since January 2017
Post by stonemon on Aug 5, 2019 9:13:39 GMT -5
Welcome to the forum from western Oregon!
Post by manofglass on Aug 5, 2019 14:25:41 GMT -5
Welcome to the forum from Michigan
Post by victor1941 on Aug 5, 2019 15:07:38 GMT -5
Call Shaun at the Rock Shed. He sells the Thumbler brand and should be able to help you.
jimaz
Member since July 2018
Post by jimaz on Aug 5, 2019 15:16:21 GMT -5
Welcome from southern Arizona.
Post by hummingbirdstones on Aug 5, 2019 15:36:29 GMT -5
Welcome from Northern Arizona!
Post by MsAli on Aug 5, 2019 17:46:12 GMT -5
Welcome to the forum!
Post by Pat on Aug 5, 2019 18:07:26 GMT -5
Not a tumbler, but welcome from California.
Post by Rockindad on Aug 6, 2019 7:30:09 GMT -5
I am new to this forum. Hoping to learn a lot from all of you. I am building a small (up to 3") sphere machine. Starting in rock tumbling also. Question: My little 3-pound Thumbler AR-1 tumbler barrel leaks a little at the lid and recently the lid came off and spilled my batch on the floor. Does anyone know of a better design that will fit this machine? Regards 1) Welcome from NY. Tons of info to be found here, both currently and going back many years. 2) We have had an AR-2 running 24/7 for eight months now and only had one tiny leak due to gas buildup in one barrel. The pressure built up inside caused a little bit of slurry to be pushed out and most of it actually dried up around the seal. This can also occur with other style barrels as well. A couple months back one of our 6 lb. Lortone barrels had the same issue when we were running glass. While both instances were limited to very minor leaks they easily could have been full blowouts if the pressure inside were allowed to keep building. If you are experiencing regular leaks you probably either have a fitment issue with your barrel/lid/O-ring or perhaps the shoulder of the inner barrel where the lid rests is not perfectly clean. Al
Post by Tommy on Aug 6, 2019 11:11:42 GMT -5
Rockshund
Post by Rockshund on Aug 6, 2019 17:53:59 GMT -5
Thank you all!
Post by Fossilman on Aug 7, 2019 9:41:45 GMT -5
Welcome!
