inbtb
Member since May 2016
Post by inbtb on Nov 19, 2019 15:13:42 GMT -5
A heel cut of Dead Camel, still needs more work but winter is here and about froze my fingers today.
I thought hot water in my sprayer would help but it did not. Don't have heat in garage so it makes it
a little tough working in water.
Post by opalpyrexia on Nov 19, 2019 15:57:54 GMT -5
Your cab looks great! It also looks like it's floating in the air. Is that an optical illusion?
jim931
Member since August 2017
Post by jim931 on Nov 19, 2019 16:42:27 GMT -5
I like it! Looks great! How high of a grit did you go?
inbtb
Post by inbtb on Nov 19, 2019 16:52:21 GMT -5
Your cab looks great! It also looks like it's floating in the air. Is that an optical illusion? Glued to a dop stick resting in a plastic bowl.
Post by Pat on Nov 19, 2019 16:55:18 GMT -5
Good looking cab! Hard to work with frozen fingers.
Post by hummingbirdstones on Nov 19, 2019 17:34:12 GMT -5
Very pretty! Just hearing about working a cab in the cold makes my fingers hurt.
inbtb
Post by inbtb on Nov 19, 2019 18:15:02 GMT -5
I like it! Looks great! How high of a grit did you go? picture was taken while working on 100 grit.
inbtb
Post by inbtb on Nov 19, 2019 18:18:30 GMT -5
Good looking cab! Hard to work with frozen fingers. Also found out super glue don't like the cold either. Want back out to do a little bit of work, bumped the stone on the table rock broke off dop stick. Now need to let rock warm up and re-glue.
Post by opalpyrexia on Nov 19, 2019 20:29:28 GMT -5
I like the look. Now I'm wondering if some sort of dop mount (double-sided tape?) might be worth exploring for taking photos for selling online...
inbtb
Post by inbtb on Nov 19, 2019 20:47:24 GMT -5
Post by fernwood on Nov 20, 2019 3:12:41 GMT -5
That is a nice cab. Can relate to the cold fingers.
inbtb
Post by inbtb on Nov 20, 2019 6:35:14 GMT -5
That is a nice cab. Can relate to the cold fingers. I really thought the hot water would help but it cools down pretty quick coming off the grinding wheel.
Post by pauls on Nov 20, 2019 17:52:40 GMT -5
That is a nice cab. Can relate to the cold fingers. I really thought the hot water would help but it cools down pretty quick coming off the grinding wheel. That cold draught that whips around the wheels is the real cause of cold fingers, I built my sanding setup with a gap at the bottom of the back guard, really to help with cleaning up but it actually slows the wind down and blows most of it out the back. I have a standard setup grinder and it is much colder to work on than the separate sander machine. Yes I use hot water too but as you say it doesn't help a lot.
Perigrine
Member since November 2019
Post by Perigrine on Nov 25, 2019 12:50:17 GMT -5
Looks great!
Can you set up a heater or maybe a hair dryer to help yourself out?
