dlaneart
Rocks and silver work heal me
Member since February 2020
Post by dlaneart on Feb 17, 2020 20:37:15 GMT -5
yep I’m a dumb
Post by stardiamond on Feb 17, 2020 20:45:48 GMT -5
What happened? The non damaged surface looks unusual. What kind of wheel and grit?
dlaneart
Post by dlaneart on Feb 17, 2020 20:54:51 GMT -5
Well I was making my mom some hand stones and the stone on the wheel I’m told was petrified wood in the final stage. Inside after the first 2 wheels was something really hard and sharp and tore it up. cab king 6 inch 280 grr
Post by stardiamond on Feb 17, 2020 21:02:16 GMT -5
My wheels seem to be more rubberized. Generally, I use hard wheels to remove anything sharp before going to soft. You should be able to get some use out of the wheel before replacing; work across the wheel and using the non damaged areas for the sides.
dlaneart
Post by dlaneart on Feb 17, 2020 21:30:20 GMT -5
This was inside the wood/Chrystal after the first 2 grits And was quite smooth and something black was just under The surface . I gave the final to mom without taking a picture so the rock/wood in the picture is a before example. I made a few other cabs after and will keep as a backup.
Post by rmf on Mar 4, 2020 22:45:15 GMT -5
ouch!!!!!
