Post by miket on Feb 20, 2020 15:52:59 GMT -5
So don't laugh, but I've been struggling keeping the barrels on my 33b from sliding to one end or the other since I got it used. Today I decided to do a little maintenance on it and saw that there's only one rubber foot on one corner on the bottom. Yeah, I'm not very observant sometimes- is that the way it's supposed to be? It just made me shake my head... Thanks.
Post by aDave on Feb 20, 2020 16:06:43 GMT -5
So don't laugh, but I've been struggling keeping the barrels on my 33b from sliding to one end or the other since I got it used. Today I decided to do a little maintenance on it and saw that there's only one rubber foot on one corner on the bottom. Yeah, I'm not very observant sometimes- is that the way it's supposed to be? It just made me shake my head... Thanks. While I don't have your specific tumbler, my other Lortones have rubber feet on every corner. When they eventually fall off, I just add new ones. Sounds like it's time for a trip to the hardware store.
Benathema
Member since November 2019
Post by Benathema on Feb 20, 2020 16:22:41 GMT -5
I think mine came with 3. One each in the two corners at the top of your image, and one in the middle at the bottom of your image. I wish these had the knurled nut guide like the bigger ones. Trying to get it as level as possible basically requires releveling it each time you put the barrels on. If one side is heavier than the other this week, the pads slightly compress and they slide towards the heavy side. I've used cardboard shims to try to get it close enough, mostly to reduce the force on those nylon guides. I've not had good luck at Home Depot finding a good size to replace them with, about to say screw it and just drill a hole through a bottle cap and call it a day.
Post by Jugglerguy on Feb 20, 2020 16:42:10 GMT -5
I think mine came with feet on all four corners. I know I’ve replaced some of them.
Post by miket on Feb 20, 2020 16:42:52 GMT -5
So don't laugh, but I've been struggling keeping the barrels on my 33b from sliding to one end or the other since I got it used. Today I decided to do a little maintenance on it and saw that there's only one rubber foot on one corner on the bottom. Yeah, I'm not very observant sometimes- is that the way it's supposed to be? It just made me shake my head... Thanks. While I don't have your specific tumbler, my other Lortones have rubber feet on every corner. When they eventually fall off, I just add new ones. Sounds like it's time for a trip to the hardware store. Yeah it's so odd- it doesn't even look like anything is missing... I guess you're right, thanks.
