moley
Member since March 2020
Post by moley on Mar 7, 2020 21:43:34 GMT -5
Hi guys,
Hope your stones are rolling well!
I was curious if I could use a desk fan motor to make my own rotary tumbler set up?
I was planning to use a pulley system to slow down the rpm. Just wondering if it would be strong enough not to burn out?
Cheers!
Post by knave on Mar 7, 2020 22:15:21 GMT -5
Doesn’t take much to turn a 3 lb tumbler. If it’s a multi speed fan, wiring could be interesting.
You may need to be more specific as in, size of barrel, info from motor. Ie, a battery powered spritzer fan won’t power a 15 lb barrel, lol
Post by aDave on Mar 7, 2020 23:11:32 GMT -5
You may need to be more specific as in, size of barrel, info from motor. Ie, a battery powered spritzer fan won’t power a 15 lb barrel, lol moley, I agree with the sentiment above. There's really not enough info in your original post to give you some guidance. You'll have to provide a bunch more specifics as to what you are trying to accomplish.
moley
Post by moley on Mar 8, 2020 9:01:04 GMT -5
Thanks for the replies, the questions you've asked me has kinda provided me with the answer... It's a 220v 45w 50hz motor. So I'm assuming it would not have much trouble spinning a 6-9lb barrel. (6-8 inches diameter, home made barrel). When pay day comes in I'll order some parts and update you guys if it works
Post by quartz on Mar 8, 2020 22:56:58 GMT -5
Is it safe to assume you live in other than the U.S.? 220v & 50 hertz is a tip. Welcome to the forum and good luck with your build.
