Post by stardiamond on Mar 12, 2020 13:20:07 GMT -5
I slabbed a small piece of Royal Imperial with my trim saw. Thick slab with a nice pattern on the bottom and a hacked up top. I started with a high dome and kept grinding until the pattern improved and a vug that was not on the bottom appeared. I now have a low dome cab and hopefully the rest of the vug disappears after sanding. Even if it doesn't the vug will be less noticeable when polished. I've got 7 preforms dopped and am waiting for the glue to set.
Post by stardiamond on Mar 12, 2020 17:03:34 GMT -5
Post by hummingbirdstones on Mar 12, 2020 19:00:36 GMT -5
Dang, remind me not to click on your photos to see bigger pictures. Now I need some eye bleach.
Post by stardiamond on Mar 12, 2020 19:47:12 GMT -5
I'm not a fan of the picture hosting site but it is easy to use. I reduce my pictures by 70% to save screen space. I can post larger.
Post by hummingbirdstones on Mar 12, 2020 20:21:57 GMT -5
That would be better. If someone is at work and clicks on one of your pictures and gets a screen full of that .....
Post by stardiamond on Mar 13, 2020 12:15:42 GMT -5
then I dropped it on the concrete and you know the rest of that story.
Post by hummingbirdstones on Mar 13, 2020 20:14:04 GMT -5
