shardy
Member since October 2019
Post by shardy on Apr 12, 2020 21:18:42 GMT -5
What else do I need to pick up to be ready to go? How much ceramic? Extra barrel? Lids? Etc. Thanks
Post by aDave on Apr 13, 2020 12:16:57 GMT -5
What else do I need to pick up to be ready to go? How much ceramic? Extra barrel? Lids? Etc. Thanks You're going to be picking up the twin-barrel Lot-O? Are you running that much rock consistently? I ask because it's designed to be run with both barrels full of material, and you can't simply choose to fill only one barrel and run it. That's alot of feeding from the front end. I don't want to dissuade you if you're actually going to be processing that much material, but lots of folks do quite well with the single barrel machine. Plus, you'll save a bit of money.
Post by knave on Apr 13, 2020 12:31:05 GMT -5
EricD has the twin model you can ask him. My single loto easily keeps up with a Thumbler B, a 3 lb HF, and any preforms and cabs from the Lortone.
shardy
Post by shardy on Apr 13, 2020 12:33:23 GMT -5
Thanks. I didn't realize it had to have both barrels full. I was going with the double just because it would be cheaper than buying another single down the road. Anyhow, what other stuff's should I get?
EricD
High in the Mountains
Member since November 2019
Post by EricD on Apr 13, 2020 12:33:36 GMT -5
I would go with a single barrel Lot-O. If you must have a dual barrel you could buy mine! I can't keep up with it.
Post by knave on Apr 13, 2020 12:38:22 GMT -5
I did not get a polish barrel, some do. Get a small bungee or rubber bands to hold the cap on. 3 - 5 lbs of large ceramic maybe 1-2 lbs of small.
brubble
Member since April 2020
Post by brubble on Apr 13, 2020 12:40:01 GMT -5
dive into this..............https://forum.rocktumblinghobby.com/thread/87024/lot-tumbling-recipes
guess you'll have to cut and paste that. worth the read.
have fun
Post by knave on Apr 13, 2020 12:40:43 GMT -5
The odd rock can and does wear on the lid. They are inexpensive and easy to lose.
Post by aDave on Apr 13, 2020 12:47:14 GMT -5
I did not get a polish barrel, some do. Get a small bungee or rubber bands to hold the cap on. 3 - 5 lbs of large ceramic maybe 1-2 lbs of small. shardy, this is pretty close to what I have done. I bought an extra barrel for polish. Small bungees from Harbor Freight to hold down the lid. I just attach the ends to the frame where the barrel sits. Others use linked rubber bands over the lid and attach them to the nipple on the bottom of the barrel. 5 pounds each of large and small cylinders and mixed the two together to vary the sizes in the batch. I haven't found a need for an extra cap.
shardy
Post by shardy on Apr 13, 2020 12:51:45 GMT -5
Excellent. Thanks for all the input. Shawn is quoting me a single tumbler, 5 pound's each large and small ceramics, and 20 pounds of stones as we speak.
Post by RocksInNJ on Apr 13, 2020 17:56:24 GMT -5
Don’t forget all the different grit and polish.
shardy
Post by shardy on Apr 13, 2020 20:44:44 GMT -5
I'm loaded down with grits. Don’t forget all the different grit and polish.
shardy
Post by shardy on Apr 14, 2020 22:01:21 GMT -5
Lot o, spare drum, ceramics, blue lace, bahias, turritella shells, and turritella agate are en route. Thanks for the advice all.
Post by knave on Apr 14, 2020 22:31:54 GMT -5
Lot o, spare drum, ceramics, blue lace, bahias, turritella shells, and turritella agate are en route. Thanks for the advice all. You’ll not regret it.
Post by TheRock on Apr 15, 2020 2:23:39 GMT -5
Just a Tip, You don't hsve to fill both barrels with rock your polishing. You can fill the second barrel with ceramics or Pea Gravel whatever you may want tp somewhat weigh the second barrel contents to balance the load.
Post by RocksInNJ on Apr 16, 2020 18:45:52 GMT -5
Congrats and best of luck. Hope you have lots of fun.
