Post by fernwood on May 4, 2020 8:13:08 GMT -5
I just received an electric wax melt pot. Was wondering if it would work as a dop pot?
Someone through it would be helpful for the lotion bars I make, but it is too small for that. It holds maybe 3/4 Cup of melted wax.
I thought I read somewhere here that it has been tried, but did not get hot enough. Cannot find that thread.
Thanks.
Post by rockjunquie on May 5, 2020 6:18:30 GMT -5
I just received an electric wax melt pot. Was wondering if it would work as a dop pot? Someone through it would be helpful for the lotion bars I make, but it is too small for that. It holds maybe 3/4 Cup of melted wax. I thought I read somewhere here that it has been tried, but did not get hot enough. Cannot find that thread. Thanks. Do you know how hot it gets? I forget the temp needed for dop wax, but it would be easy enough to find. Just compare the 2 temps.
inbtb
Member since May 2016
Post by inbtb on May 8, 2020 17:17:16 GMT -5
I bought a glue pot to use for dop wax. The temp gets up to 250/260. Don't know if that is hot enough as the stones keep coming off the dop stick. What temp do dop pots operate at?
Post by rockjunquie on May 8, 2020 17:58:48 GMT -5
I bought a glue pot to use for dop wax. The temp gets up to 250/260. Don't know if that is hot enough as the stones keep coming off the dop stick. What temp do dop pots operate at? Green wax softens and melts at 150-160. If you overheat the wax, some of it (the shellac probably) burns out, ruining the wax. You don't want it too thinly melted. It should still be kinda thick.
inbtb
Post by inbtb on May 8, 2020 18:28:41 GMT -5
Looks like I'm going to be buying a dop pot.
Post by Starguy on May 11, 2020 10:52:56 GMT -5
Post by rockjunquie on May 11, 2020 13:52:03 GMT -5
That's what I have. It has served me well.
Post by glennz01 on May 18, 2020 2:14:25 GMT -5
I just received an electric wax melt pot. Was wondering if it would work as a dop pot? Someone through it would be helpful for the lotion bars I make, but it is too small for that. It holds maybe 3/4 Cup of melted wax. I thought I read somewhere here that it has been tried, but did not get hot enough. Cannot find that thread. Thanks. Yes, I got one locally used for $20. It was wax melt used at nail salon. Has variable temperature works great. Also an old timers method my dropping sticks have screw heads for the ends. I hardly ever dip but for earrings I must.
