joshua731976
Member since May 2020
Post by joshua731976 on May 7, 2020 15:41:26 GMT -5
Can I please have help identifying this rock that I found it is very heavy very cold at all times it is very deep underneath the top layer of dirt
lookatthat
Member since May 2017
Post by lookatthat on May 7, 2020 17:33:45 GMT -5
Post by knave on May 7, 2020 19:27:53 GMT -5
From your description I would say permafrost.
dreamrocks
Member since November 2018
Post by dreamrocks on May 8, 2020 2:20:52 GMT -5
Well if it’s not permafrost it’s a stone the Inca use to use called the invisible stone what you do is grind it up in to a fine powder mix with water then drink it and kaboom your invisible. Or you could put the rock in your mouth until you disappear and then you can become invisible when ever you want then you can reappear and disappear at will. But by the looks you must have got it wet now you just have to let it dry until you can find it again.
Post by hummingbirdstones on May 8, 2020 8:47:59 GMT -5
joshua Your picture isn't showing.
Post by Tommy on May 8, 2020 9:28:59 GMT -5
Can I please have help identifying this rock that I found it is very heavy very cold at all times it is very deep underneath the top layer of dirt Hi Joshua if you need help posting a photo of it please let us know. You can email it to me and I'll post it for you if you want.
