julieooly
Post by julieooly on May 13, 2020 7:38:02 GMT -5
Post by opalpyrexia on May 13, 2020 9:47:56 GMT -5
I have the Ameritool trim saw, Julie, and I use it at full speed. Because I am controlling the feed rate I see no benefit to slowing down the blade RPM.
Post by Pat on May 13, 2020 10:41:33 GMT -5
I have the Ameritool trim saw, Julie, and I use it at full speed. Because I am controlling the feed rate I see no benefit to slowing down the blade RPM. I have the same saw. Always on highest speed.
Post by Peruano on May 13, 2020 10:59:19 GMT -5
A very thin blade will spin truer (i.e. with less wobble) at a high speed. Note that direct drive saws are often higher rpms than belt driven. I can imagine that slowing the speed might be desirable on some stones that chip or
