mrhomescientist
Member since October 2019
Post by mrhomescientist on May 14, 2020 14:00:36 GMT -5
I'm working on tumbling some labradorite rough I bought from the Rock Shed, and from what I've read around here it's pretty tough to get right. I'm using the procedure from this thread: forum.rocktumblinghobby.com/thread/36957I'm using 3lb tumbler barrels. I first put the rough stones in with my usual stage 1: 3 tbsp of 60/90 SiC, for one week. (This was before I read that thread recommending no grit; I've got one of those running right now.) This smoothed them out nicely for the most part, though I had to run a couple weeks on a few of them. Once I got enough for stage 2, I followed the advice of the thread and loaded it up with plastic pellets. I used more grit than he did, though, at 2 tbsp of #220. Here's the barrel before adding the grit: Here's what they look like after 1 week: Some observations: The labradorite actually feels more rough than when I put it in! It's very strange. It looks like the pellets have "absorbed" the grit - that gray won't wipe off. Interestingly, the grit leftover in the rinse water looked almost as good as new. I could see a lot of sparkling grit particles instead of the usual dull mud I see at the end of a run. Hypothesis: Maybe I used too many plastic pellets? I wanted to cushion the stones as suggested, but they may have been too cushioned to grind against the grit. Any suggestions on how to proceed from here?
pizzano
Member since February 2018
Post by pizzano on May 14, 2020 14:39:04 GMT -5
Lab is tricky.......
Rock buddies I know who rotary tumbled this material started out using 120/220 silicon carbide (not a 60/90) with a mix of smaller like hardness material (no pellets or ceramics). The smaller material helps provide volume and surface contact as the slurry develops.
Once they've gotten the shaping/rounding they desire, most success completing to a polish has been done in a Vibe type tumbler with small (previously used) ceramics.....using a 500 Alum Oxide, then an Alum Oxide pre-polish (1000 or higher), then a high end polish compound or Cerium Oxide.........this material is difficult to achieve a "fracture" free polish in a vibe and even more difficult in a rotary.....but it can be done.
The link.....:
will help, but the attention to detail is lacking some.......this material takes considerable baby-sitting......no two batches will have the same outcomes.
With a little experience and patients, you'll get there.......not suggested as a material for 1st timers....!
Post by miket on May 14, 2020 15:10:04 GMT -5
I tried it once and failed miserably. I had a cab that I made, ran it in the rotary for about a week in coarse then in the vibe for a week to finish. Keep us posted on how you turn out, I like Labradorite- and good luck!
Post by pauls on May 14, 2020 21:33:53 GMT -5
I think you are doing OK with a difficult material. You probably overdosed with grit but that's not a deal breaker. The pellets would have cushioned the grit from breaking down. Clean them up, and move them on to the next grit, new pellets though.
JBe
Post by JBe on May 15, 2020 11:42:26 GMT -5
Thanks for posting this! I have a pile of lab I've been accumulating until I have enough for a dedicated batch and would love to be able to learn from other peoples' experiences with it.
I've tried plastic pellets before and had them stain/absorb grit as well. I kept separate pellets for each grit stage just to be safe.
Post by pauls on May 15, 2020 21:37:50 GMT -5
That sounds good JBe. I have tumbled a few different types of Feldspar to clean them up. I facet so looking for nice clean flaw free material, this doesn't get the luxury treatment of my good rocks just enough to polish so I can see inside, it does take a good polish if you can stop it fracturing along cleavage planes. It facets really nicely too, our Labradorite here in Australia is just a nice clear honey colour, no blue schiller, so perfect for faceting.
