dreamrocks
Member since November 2018
Post by dreamrocks on Jun 8, 2020 5:17:53 GMT -5
dreamrocks
Post by dreamrocks on Jun 13, 2020 8:28:51 GMT -5
I had to check this stuff there was nothing special to this particular piece at all no clear sections I wanted to mainly know how blast shattered it was. Apparently not so bad that tells me the other pieces are worth taking my time to cut out the clear pieces out in the bigger chunks this is not quartz by the way. I tested the specific gravity the test told me it was beryl how much is yellow is the question I also tested a piece of quartz to check the difference in the two. I should be able to get facet and cab material from what I collected the other day.
