saxplayer
Member since March 2018
Post by saxplayer on Jun 27, 2020 21:01:59 GMT -5
So, my lot-o action lately hasn't been great. I looked closer at my springs (there are 2 pairs in the back under the motor and 2 single springs in the front). ONE of the lower springs on the back under the motor was broken. So, I ordered a set of 6 new springs and decided to replace them all just for giggles.
this SUCKED. I am not sure what tools I don't have, but none of the spring screws under the motor were easily accessed. I had to use a pliers to grip and turn each small hex-nut. To get the new springs screwed back into the base was a major pain in the a**. I'm not sure I didn't ruin the head if I need to do this again in the future.
Does anyone have tips / tooks or tricks the suggest for getting at these springs easier?
Grant
EricD
High in the Mountains
Member since November 2019
Post by EricD on Jun 27, 2020 21:04:33 GMT -5
1/4 and 3/16 tools. If they are gearwrenches it's even better!
saxplayer
Post by saxplayer on Jun 27, 2020 22:00:22 GMT -5
1/4 and 3/16 tools. If they are gearwrenches it's even better! I have those size tools but nothing that can fit the heads with the frame. Can you suggest something? EDIT - I'll find a small wrench that is 3/16 but the one I had was small. Really couldn't fit it under the frame
EricD
Post by EricD on Jun 27, 2020 22:57:04 GMT -5
Under the frame is 1/4, if I remember right on top it's 3/16 or 5/16 the 2 confuse me constantly. Would rather use metric measurements
oregon
gem lap trim saw
Member since August 2015
Member is Online
Post by oregon on Jun 28, 2020 12:09:40 GMT -5
Aren't they pan heads underneath? I usually unscrew the springs from the board have access to the bottom of the frame that way. (been very pleased with my used sawzall blade replacement springs
saxplayer
Post by saxplayer on Jun 28, 2020 12:27:45 GMT -5
Aren't they pan heads underneath? I usually unscrew the springs from the board have access to the bottom of the frame that way. (been very pleased with my used sawzall blade replacement springs Yes they are. Getting the 4 outer screws out is hard (just the 2 under motor). I can’t get a tool on them to turn except pliers.
EricD
Post by EricD on Jun 28, 2020 12:32:38 GMT -5
Aren't they pan heads underneath? I usually unscrew the springs from the board have access to the bottom of the frame that way. (been very pleased with my used sawzall blade replacement springs Yes they are. Getting the 4 outer screws out is hard (just the 2 under motor). I can’t get a tool on them to turn except pliers. That's weird. Mine are all 1/4" hex bolts/screws
Post by toiv0 on Jun 30, 2020 2:26:32 GMT -5
Aren't they pan heads underneath? I usually unscrew the springs from the board have access to the bottom of the frame that way. (been very pleased with my used sawzall blade replacement springs Tell us more about the sawzall blade replacements. I was considering using metal strapping, but the blade thing sounds tough.
Post by toiv0 on Jun 30, 2020 2:28:03 GMT -5
Aren't they pan heads underneath? I usually unscrew the springs from the board have access to the bottom of the frame that way. (been very pleased with my used sawzall blade replacement springs Yes they are. Getting the 4 outer screws out is hard (just the 2 under motor). I can’t get a tool on them to turn except pliers. I can't remember having any issues changing mine and I am not near it to look because of working on the road.
saxplayer
Post by saxplayer on Jun 30, 2020 7:54:55 GMT -5
I ordered a mini wrench set on amazon that should fit I hope.
