EricD
High in the Mountains
Member since November 2019
Post by EricD on Jul 5, 2020 20:05:02 GMT -5
Good looking load if that's what it is!
Post by stardiamond on Jul 5, 2020 20:17:53 GMT -5
I've probably made cabs from over 50 different materials. I never made a coprolite cab. There seems to be a wide variety of colors and patterns.
Post by opalpyrexia on Jul 5, 2020 22:34:51 GMT -5
Nice — you’ve got some great patterns in those.
Post by RWA3006 on Jul 5, 2020 22:41:55 GMT -5
I can tell you that it is indeed coprolite. I have many thousands of specimens and my poo radar confirms the ID.
Post by hummingbirdstones on Jul 5, 2020 22:49:00 GMT -5
Pink poop! Gotta love a dinosaur that eats strawberries.
agatewhisperer
Member since May 2020
Post by agatewhisperer on Jul 5, 2020 22:50:39 GMT -5
I can tell you that it is indeed coprolite. I have many thousands of specimens and my poo radar confirms the ID. Good to hear! What do you look for that identifies it as poo?
Post by rockjunquie on Jul 6, 2020 9:39:15 GMT -5
Man, that is nice as sh*t! Seriously, that's some pretty good stuff right there. Like the color and contrast.
agatewhisperer
Post by agatewhisperer on Jul 6, 2020 17:14:50 GMT -5
Finished cutting it today minus a thick slab I'll need to split later. Here's a pic of the rest of the load.
Post by pauls on Jul 6, 2020 17:35:56 GMT -5
I can tell you that it is indeed coprolite. I have many thousands of specimens and my poo radar confirms the ID. Good to hear! What do you look for that identifies it as poo? Drop it on the floor of your workshop, if you accidently step on it you know it is poo.
Post by RWA3006 on Jul 6, 2020 18:53:16 GMT -5
I can tell you that it is indeed coprolite. I have many thousands of specimens and my poo radar confirms the ID. Good to hear! What do you look for that identifies it as poo? The texture in your specimen is a dead give away. It is very similar to the coprolites from Southern Utah which were produced mostly from various hadrosaurs. The plant material they ate was mostly conifers, ferns, cycads, algae, and they had crude peg-like teeth which did not chew the food very thoroughly, hence the coarse texture of the fossil. The presence of gastroliths within a specimen is also another clue pointing to it's identity. I've found hundreds of gastroliths (gizzard stones) embedded inside coprolites when cut open. Most do not show gastroliths, but enough do that I consider it to be common. They usually range in size from a match head to a pea, but I've found golf ball sized ones also. This in coprolites ranging from walnut to water melon sizes. I could not discern gastroliths in your photos, but you might look closely and see one. They usually appear to be of different stone and look "out of place." They will almost always be rounded from getting tumbled. The exterior shape and texture are also good indicators. If you imagine coarsely ground plant material falling out of a cement mixer you get the idea. Many of them are flattened on one side where they went "splat" and you can often see pebbles embedded into the flat side, just like what many farm kids see from the family milk cow dropping a load onto the gravel road. Not all of them have this shape but are more like elephant droppings ... firm, dry, and coarsely chewed. I've also found micro remnants of coral and crustacean shells within them. I speculate the critter gulped mouth fulls of beach gravel to replenish the grit. Southeastern Utah was probably beach front property at that time with ocean toward the southeast. Laurasia had recently split into land masses of North America and Eurasia. North America was drifting North and passing through tropical latitudes at that time. My finds come out of the Morrison formation dating 146 to 156 million years ago. Guess that's enough on a crappy subject.
EricD
Post by EricD on Jul 6, 2020 19:17:09 GMT -5
Good to hear! What do you look for that identifies it as poo? The texture in your specimen is a dead give away. It is very similar to the coprolites from Southern Utah which were produced mostly from various hadrosaurs. The plant material they ate was mostly conifers, ferns, cycads, algae, and they had crude peg-like teeth which did not chew the food very thoroughly, hence the coarse texture of the fossil. The presence of gastroliths within a specimen is also another clue pointing to it's identity. I've found hundreds of gastroliths (gizzard stones) embedded inside coprolites when cut open. Most do not show gastroliths, but enough do that I consider it to be common. They usually range in size from a match head to a pea, but I've found golf ball sized ones also. This in coprolites ranging from walnut to water melon sizes. I could not discern gastroliths in your photos, but you might look closely and see one. They usually appear to be of different stone and look "out of place." They will almost always be rounded from getting tumbled. The exterior shape and texture are also good indicators. If you imagine coarsely ground plant material falling out of a cement mixer you get the idea. Many of them are flattened on one side where they went "splat" and you can often see pebbles embedded into the flat side, just like what many farm kids see from the family milk cow dropping a load onto the gravel road. Not all of them have this shape but are more like elephant droppings ... firm, dry, and coarsely chewed. I've also found micro remnants of coral and crustacean shells within them. I speculate the critter gulped mouth fulls of beach gravel to replenish the grit. Southeastern Utah was probably beach front property at that time with ocean toward the southeast. Laurasia had recently split into land masses of North America and Eurasia. North America was drifting North and passing through tropical latitudes at that time. My finds come out of the Morrison formation dating 146 to 156 million years ago. Guess that's enough on a crappy subject. That was awesome. Appreciate you taking the time to type it!
Post by RWA3006 on Jul 6, 2020 19:19:26 GMT -5
Thanks Eric. That was better than telling me "you're full of crap." Haha
EricD
Post by EricD on Jul 6, 2020 19:29:08 GMT -5
Thanks Eric. That was better than telling me "you're full of crap." Haha Oh my... Who would ever do such a thing?!
kyoti
Member since June 2020
Post by kyoti on Jul 7, 2020 18:54:28 GMT -5
Those are some nice looking slabs. I might have to start looking for some poohs when I'm fossil hunting if they look like that inside I wonder how they mineralize in this area.
