Post by stardiamond on Jul 19, 2020 11:24:25 GMT -5
A few months ago I bought a parcel of small Tahoma rough. Tahoma is a seam agate and should generally be cut across the seam so the pattern goes through the slab. I had a small piece that was too thin to cut against the seam. I put it away. I don't throw out much because sometime it is hard to tell what can never be used. The piece was about 1/2 inch thick with matrix on both sides and one side relatively flat. Sometimes I grind off the matrix but I thought I could make one slab shaving off the matrix with my slab saw. Everything worked out and I ended up with a .22 inch slab with an atypical pattern. It looks a little like frogskin and have made some cabs with the pattern in the past. The pattern goes all the way through.
Post by HankRocks on Jul 19, 2020 11:38:31 GMT -5
Nice looking material.
I suspect that most out here easily identify with "I don't throw out much as it might be used". It's in the DNA of most Rockhounds!!
Post by stardiamond on Jul 19, 2020 15:55:51 GMT -5
I thought there might be a surface fracture so I worked on it through 280 soft. I have this one and six more to finish tomorrow. Today is be kind to my back day.
