Someone I know once said, "A cabochon is a cabochon, and a flat shaped rock is a flat shaped rock."
In 2019, there was a discussion here about what the parameters of a cabochon are.
There are also guidelines for evaluating cabs, sort of like how well dogs entered in dog shows meet their breed standard.
Points are given for how well cabochons meet the definition/criteria of a cab.
Rather than post links to various places, I will just paste my post in it's entirety.
Tuscarora Lapidary Society, Inc.
Skill
Improvement
Program
Rules
Regulations
Judging
Instructions
24 Upland Road
Brookhaven, PA 19015
610h490h5252
www.lapidary.org© Tuscarora Lapidary Society, Inc. All Rights Reserved. No part of this document may be sold, reproduced, or transmitted in any form, physical, digital
or electronic. TLS does grant individuals and non-profit clubs permission to freely download, use, and reproduce this document under the condition that
it be clearly attributed to TLS and that the copyright notice remain intact.
2
SKIP — The TLS Skill Improvement Program
Tuscarora’s Skill Improvement Program (SKIP) is dedicated to increasing enjoyment of our hobby by the
development of higher levels of craftsmanship. Each member is given the opportunity to have his/her work
evaluated in relationship to standards of workmanship. These standards become progressively more rigorous as
the member’s skill increases.
3
CABOCHON DIVISION
Definitions
A cabochon is a polished stone with a domed surface (the top), cut freehand (not tumbled). The second surface (the
back) may be flat or domed. If domed, it may be of lesser height than the front dome. A cabochon is normally of a
size suitable to be worn as jewelry.
A standard cabochon is one whose girdle outline has at least one axis of symmetry. All patterns on the standard
templates satisfy this condition.
A free-form cabochon is one whose girdle outline has no symmetry.
The bezel angle is the slope that is cut on the side of a cabochon for a short distance above the girdle; it should
be uniform around the stone. Its purpose is to allow the bezel of a mounting to be rolled or pressed down against
the stone to secure it in the mount. It should be in the range of 10 to 15 degrees. The dome may meet the bezel
angle surface in a definite line, parallel to the girdle, or may blend in smoothly down to the girdle.
The chamfer or bevel is a narrow angled surface cut around the girdle of a cabochon toward the back to reduce
the likelihood of chipping. It should be about 45 degrees, of uniform width, not wider than 1mm except on very
large stones.
Note that cabochons with two domed surfaces have no chamfer, and that the angle at which the back surfaces
meet the girdle may be much larger than the bezel angle on the front. Ideally, the girdle in this case would be
sharp. Because of chipping, this is not practical and the girdle must be slightly and smoothly rounded.
The symmetry overall refers to the contour of the domed surfaces, not to the shape of the girdle.
Orientation refers to the shaping of the stone to make best use of its natural patterns, color distribution, and
inclusions to show chatoyancy, cat’s-eye, star, or to otherwise enhance the beauty of the finished piece.
Examples that illustrate the definitions
Material
A cabochon may be made of any suitable natural mineral or any synthetic mineral-like material, such as
goldstone. The quality of the material refers to color, pattern, freedom from cracks, pits, etc.
4
Point Allocation for Evaluation
STANDARD CABOCHONS
Accuracy of girdle outline* 15
Symmetry overall (shaping of top & sides)
Top 10
Sides 10
Quality of polish
Top 10
Sides 10
Orientation 10
Quality of material 15
Bezel angle 10
Chamfer or bevel 5
Back 5
Perfection 100 points
*Free form cabochons: For accuracy of girdle outline, substitute complexity of form attempted.
Polished flats will not qualify in the Cabochon Division.
Judging
Accuracy of girdle outline: For traditional shapes — check by placing template over (or carefully tracing outline)
then placing template over traced outline, then cutting out and folding; freeform — shape that exhibits skill.
Symmetry overall: Make a light move over the stone. If the reflection changes shape or jumps, instead of
moving evenly over the top, then symmetry is off (flat spots).
Quality of polish: Check by looking at light reflection on stone (use a clear light bulb). Softer stones may not
take as high a polish, nor will stones of mixed minerals.
Quality of material: Take into consideration the quality for this particular material.
Bezel angle: The interface between the bezel and the top should be either smoothly rounded or have a nice
sharp edge.
Chamfer: Must be even all around — no chips.
Bottom: All stones submitted should be clean on the backs, with all saw marks, all aluminum pencil, or other
marks sanded off. Cabochons with two domes must have both polished. Clear or translucent material
cabochons must be polished on the back as well.
Judging will be done using 10X magnification.
SKIP program
Information on entry requirements and different levels of craftsmanship PDF
HERE
Agree with it or not, this was originally what it was about.
