lparsons
Member since April 2020
Post by lparsons on Aug 5, 2020 23:39:36 GMT -5
I was wondering if it was common to use strong chemicals to clean extremely dirty rocks before tumbling.
Post by pauls on Aug 6, 2020 0:54:17 GMT -5
I can't think of any good reason why you would even think about doing it. Put the rocks in the tumbler with some water and grit run it for a while your rocks will be clean, You could even do it without the grit and it would work.
Post by jamesp on Aug 6, 2020 6:21:35 GMT -5
agree with pauls. Best rock cleaner on earth is a rock tumbler. i remove rust off of steel in a rotary tumbler using road gravel for abrasive. Nothing beats it.
Post by Mel on Aug 21, 2020 14:52:20 GMT -5
agree with pauls . Best rock cleaner on earth is a rock tumbler. i remove rust off of steel in a rotary tumbler using road gravel for abrasive. Nothing beats it. Dang James, is there anything you can't do? (Just love reading your posts, always learn something).
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Aug 22, 2020 6:51:58 GMT -5
Stage 1 is the cleaning step, at the end of stage 1 your rocks will be clean and rounded. I used to clean the rocks before Stage 1, but it really does not matter. The cleaning and rounding all help to form a thick slurry that helps the first stage go faster.
