Post by rockjunquie on Jul 29, 2022 16:38:36 GMT -5
This incredible thread is being honorably moved to the tutorial section where it will still be open and available.
Post by Bob on Aug 1, 2022 15:13:55 GMT -5
Since this test began, in normal tumbling I have finished perhaps 50lbs of polished rocks which are in containers in my house in addition to all others I've done. This test has been so revealing, that I'm leaning toward expanding it into other polishes. As one example, what might happen with using only ground walnut shells? I have the methodology developed, and have kept all the rocks separated, so my mind is already on the next saga which I might start this fall.
Associated with that is what have I learned about the materials and which ones matter for comparisons and which don't? I looking at all the shiny rocks laying around in my house, one thing comes to mind. All the quartzes, more or less, are in one group and there is probably no need to split up that group. It seems they are all tight and smooth after grinding like I do to perfection, and either they polish, or they don't so well. But the whole batch is almost always alike, and, they almost always polish superbly. Also, even if there is some rock that breaks they still almost always polish superbly, rather than being damaged by that broken rock. Maybe it's because they are all so tough.
They all have the perfect shine, or maybe not, but there just isn't variation within the batch it seems. This includes various categories we mention--the agates, jaspers, cherts, onyxes, and misc. uncategorized chalcedonies (like fire "agate", Moss "agate", Binghamite, Damsonite, etc. It also includes petrified organic material such as pet wood, pet coral, Larsonite, etc. This is the same as saying I see no reason in general tumbling to tumble or polish them separately from each other and indeed that has been my practice for years and with good results.
From my small experience, all these materials are some of the easiest to process and get a great shine, even with no cushioning used at any stage, including polishing, if there is sufficient size variety including plenty of smalls. I see no reason really to have to use more then one of them in the test going forward.
However, there is one subgroup of quartz that behaves uniquely and, to me, doesn't share all the above. The macrocrystalline quartzes such as amethyst, smokey quartz, rose quartz, etc.--at least the material I seem to get or find--is touchy. The surface almost always has tiny crevices remain here (edges of fine fractures mostly) and there even after careful grind up to prepolish. And it's brittle and can chip. And sometimes a polish run with it goes well, and sometimes not. When it goes well, it's equally shiny or not as shiny as all the other quartzes. I tend to think any challenge in polishing it perfectly is more of a cushioning issue.
So my thought going forward on this category is to have only: 1 agate or 1 jasper, and maybe 1 macrocrystalline quartz such as mentioned above. Ironically, I had smokey quartz ready for this test, 4 nearly identical piecea about the size of a grape, and somehow forgot to include it.
The fewer different rocks in my test, the larger specimens I can use too which might be beneficial.
If anyone has guidance or criticism on this idea, please mention.
Post by Bob on Aug 2, 2022 9:42:42 GMT -5
When I sorted out the comparison cards for that group, there were 13 of them, all of which had tin come out 1st. In 4 of them, alum also tied with tin for 1st. So replacing these 13 with just 1 material going forward will simplify everything. I will probably choose western Oklahoma chert because I have so many pieces to choose from and can pick 4 or more (depending upon how many polishes being compared) of nearly identical size and in about any size.
Post by Bob on Aug 3, 2022 9:29:56 GMT -5
I had meant to include for that large quartz group what polish the literature had recommended the most. It was alum, but with some exceptions.
It was cerium for Pure Quartz (Rock Crystal), the onyxes, Fire "Agate", petrified wood, and "Turritella agate".
It was tin for pet corals.
I could find nothing in the literature for Binghamite, Chrome Chalcedony, petrified algae, pet feces (Coprolite), and pet fossilized fern. For petrified dinosaur bone, although I found no polish recommended I did find mention that specialized methods were typically needed but those were not explained or I didn't make a note of them.
Post by Bob on Aug 3, 2022 9:54:03 GMT -5
The next largest materials group in the comparison test is the feldspars. I drove me nuts trying to come to an understanding of how this group works and the rocks and minerals within it are classified. It would certainly be convenient if in any polish testing I do going forward, I could determine that only one of these was necessary because they all polish similarly.
The literature predicted tin is the polish to use. The members of this group which I found to be on the market for tumbling are:
*Amazonite, a named variety of the mineral Microcline. Larvikite (Black Moonstone, Blue Pearl Granite), an igneous rock which is a mix of several feldspars. Graphic Feldspar (Zebradorite, Punjabi Stone), exact classification unknown. *Moonstone, a named variety of the mineral Orthoclase which also contains some plagioclase called Albite. *Uncategorized Orthoclase, a mineral. Perthite, exact classification unknown but a mixture two interwoven feldspars. Bytonite (Golden Labradorite, Yellow Labradorite), named varieties of the mineral Labradorite. Spectrolite, a named variety of the mineral Labradorite. *Uncategorized Labradorite, a mineral. Oligoclase, a mineral. Sunstone, a variety of the mineral Orthoclase, or of the Plagioclase series.
If any mistakes were made in that please let me know as I'm not a mineralogist.
I had 4 in the test, those with a *, because those were the only ones I had. Tin was 1st for all, but except for that, the results were mixed. Chrom never did well. Cer tied with tin in 1st for Amazonite. Cer and alum tied with tin for 1st with Orthoclase.
Tumbling feldspars, to me, is challenging. They are all touchy, and many pieces don't make it to the end. I highly suspect to some extent the results in polish are due to many factors and that my polish test for these might be different if the polish test contained only feldspars. The Mohs range from 6.0 to 7.0 and many are 6.0 to 6.5, so these are less than the quartzes which are reported 6.5-7.0.
My inclination going forward is to not try to combine this group but rather to use as many members of it as possible because of the anticipated wide variety of behaviors in polish. In fact, I might even make a comparison run using only members of this group, and with more than 4 polishes.
Post by Bob on Aug 4, 2022 13:27:37 GMT -5
Another group is Glass which can be divided into Man-made glass and naturally occurring glass called Obsidian. Because so many tumblers experienced with Obsidian have mentioned how touchy Obsidian is, I'm not inclined to do any more polish testing that doesn't include both of these kinds of glass. They have also mentioned that Obsidian polish results have varied with the type of Obsidian and even between batches and different pieces of the same type. So that's why I chose Apache Tears Obsidian that had come from the same purchased batch. If that isn't done, I guess the ideal would be to cut up an individual piece into separate pieces to test to make sure all the same.
Post by Bob on Aug 5, 2022 11:28:27 GMT -5
All of the other materials seem to be individually unique minerals or rocks, and so continuing to include them in testing if any more is done seems the way to go.
I also have some pretty granites and basalts and a few other type rocks especially from the N shore or Lake Superior. These have not polished in the past for me, so I do 1,200 grit and then stop and keep only those with a very tight, smooth surface. But to my recollection, this was only after testing with cerium. The next time I expand this test, I will include some of them. Would be amazing to me if tin somehow worked something magical on them.
As far as I can tell, there is nothing to be gained by me making any more comments in this thread until when and if I decide to include more than these 4 polishes, or have enough new types of material to add to the test. All input, critical or otherwise, is always welcome.
Post by rockjunquie on Aug 5, 2022 11:33:41 GMT -5
I hate to see it end!
Post by Starguy on Aug 5, 2022 17:33:41 GMT -5
I’ve followed this thread from the beginning. I love that Bob went through all the trouble. I’m sticking with tin oxide as my polish of choice. It’s expensive but it always works.
Post by thisislandearth on Aug 11, 2022 19:07:10 GMT -5
All of the other materials seem to be individually unique minerals or rocks, and so continuing to include them in testing if any more is done seems the way to go. I also have some pretty granites and basalts and a few other type rocks especially from the N shore or Lake Superior. These have not polished in the past for me, so I do 1,200 grit and then stop and keep only those with a very tight, smooth surface. But to my recollection, this was only after testing with cerium. The next time I expand this test, I will include some of them. Would be amazing to me if tin somehow worked something magical on them. As far as I can tell, there is nothing to be gained by me making any more comments in this thread until when and if I decide to include more than these 4 polishes, or have enough new types of material to add to the test. All input, critical or otherwise, is always welcome. Bob, I've followed the thread from the start. So very impressive! One question I had, and maybe I just missed it - when you use a polish other than Aluminum Oxide what do you use for your pre-polish. For example, if I was going to use Tin Oxide is it still ok to use Aluminum Oxide as the pre-polish? Is there a Tin Oxide pre-polish? Maybe a pre-polish makes no difference provided we're talking about a 1000-1200 any pre-polish grit. On the other hand, I wouldn't use 500 grit Silicon Carbide ( sharp edges I think ? ) over 500 grit Al Ox... Thanks
Post by Bob on Aug 11, 2022 23:03:09 GMT -5
I merely call the step before polish pre-polish. 1,000 silicon carbide is the one I use, including in the test.
Post by Bob on Feb 7, 2023 12:00:18 GMT -5
For all who have followed this, I wanted to share what I'm thinking about doing next. All the test rocks were kept as is. I'm thinking about doing a burnish test so see just how well it works on all these materials. To do this, I would first take them all back to unpolished by a run in 1,000 grit. Then I need to polish them all to get them ready. I guess the way to do that would be to polish them in the polish that did the best for each.
Then take the polished rocks and divide into 2 groups, which would allow for 2 rocks of each type. One group would be the control group to just remain. The other group would be to be burnished and then photograph the comparison results.
Another option would of the 4 rocks of each type divide them as follows:
Group 1 control group do nothing after polished again. Group 2 burnish for what I typically burnish for 12 hours (or 24 hours?). Group 3 burnish for something less than that, such as 3 hours. Group 4 burnish for 3 days or something like that.
If anyone has better ideas, I'm listening.
dirtsifter
Co to za kamyczek?
Member since September 2022
Post by dirtsifter on Feb 10, 2023 2:05:32 GMT -5
Bob, I just read this entire thread start to finish tonight. My goodness, what an incredible piece of work this thread documents. As a new (< 1 year) tumbler, I really learned much. Thank you. In your last post about continuing this odyssey, you mention burnishing. I burnish also but please describe your burnish method because my understanding of burnish and your burnish may be different.
Post by Bob on Feb 10, 2023 16:23:59 GMT -5
Bob , I just read this entire thread start to finish tonight. My goodness, what an incredible piece of work this thread documents. As a new (< 1 year) tumbler, I really learned much. Thank you. In your last post about continuing this odyssey, you mention burnishing. I burnish also but please describe your burnish method because my understanding of burnish and your burnish may be different. You will find a wide variety of approaches, but what I do is probably typical or average. After polish, rinse, then burnish with Ivory soap flakes carved off with a knife. I use a full small size bar in a 12lb barrel. It usually improves the shine a little, and sometimes quite a bit, and rarely not at all. Some people do for only "overnight" meaning I suppose 10-12 hours. Some for 1-3 days. It's rare that people do more. I have not experimented a whole lot with it myself, but so far have not noticed much difference between that happens overnight vs. going for a few days. So I've typically done 1/2 to 1 day. All that was about average Mohs 7 rocks. For specialty stuff like obsidian, it gets almost mystical as to what people might do...
Post by Bob on Feb 14, 2023 12:13:53 GMT -5
This is what I've decided to do. What if burnishing changed any of the outcomes of the polish test? Is it unlikely? I think so. But if I don't put those 4 existing batches through a burnish before doing anything else with them, we will never know. So I can't afford to run them through 1,000 grit to get them ready for anything else before doing that or I will lose that chance.
So, I'm going to first wash them off to get rid of any dust, then put them through burnish and see what happens. Boy will I be shocked if, for instance, burnish were to bring the shines from the different polishes on some materials to being equal when before burnish they were not equal. I keep plastic pellets on hand that are only used for burnishing, so are very clean and I will use them for cushioning. The first of the 4 sets will likely start in about a month. I have to make sure I have done a polish run through the 6lb barrel first before using it for this.
As to how long, 12 hrs, 24 hrs, etc. going to have to think about that.
rockinronda
Member since December 2023
Post by rockinronda on Dec 21, 2023 17:36:14 GMT -5
Hey Bob, thanks for taking the time and having the impetus to do this experiment! I have read the whole thing and love all the pics! You really can see a difference across the board and this furthers my opinion Tin Oxide provides the best polish, generally. I will now also save my polish (after rinsing and drying) to reuse as a polish or polish stage 2, since I read in here it breaks down to even finer material. That will save a literal ton of money! Did you ever conclude the burnish experiment? What were the findings?
rydersrocks
Likes rocks of all kinds
Member since January 2024
Post by rydersrocks on Jan 22, 2024 14:22:25 GMT -5
A lot of stuff goes on when polishing rocks. I have some secrets I know to get a better polish, but Im keeping that a secret. It all depends on how much rock there is, how much pressure is in between the rocks when they collide, what the polish and rock is made of. The first couple of stages are very important in order to get a good shine. The rock has to be as smooth as possible before polishing. Im excited to see the full results!
