charleslleaf
Member since September 2020
Post by charleslleaf on Sept 6, 2020 12:44:47 GMT -5
Greeting folks. I am new to this forum which looks like a wealth of information I will enjoy reading through. Currently, I am in dire need of a partially keyed threaded shaft as follows: 8" long by 3/4" diameter Keyed to 2 1/2" long by 3/8" wide 5/8” thread length This shaft (now unfortunately bent) fits in my Highland Park rock saw. See the shaft here... linkDoes anyone know what they call this type of shaft, and where I could possibly find one? Your help would be greatly appreciated. Much thanks, Charles
Post by hummingbirdstones on Sept 6, 2020 15:42:35 GMT -5
Hi and welcome from Northern Arizona!
Check with HP to see if they have one here. If you don't see it on there you can give them a call to see if they can help you out.
stonemon
Member since January 2017
Post by stonemon on Sept 6, 2020 15:56:13 GMT -5
Welcome to the forum!
noiefish
Member since August 2020
Post by noiefish on Sept 7, 2020 11:38:58 GMT -5
Is it your arbor shaft? You should be able to find it by cling on the "Arbor Parts" subsection for your saw part.
Post by melhill1659 on Sept 15, 2020 17:24:46 GMT -5
Ask Tony, catmandewe, he refurbishes saws all the time so he may can help.
Post by catmandewe on Sept 16, 2020 17:47:55 GMT -5
I have some that I had machined for me out of high quality steel, they dont have the keyway cut into them but you can drill in your set screws if you want a solid setting. They are more expensive than the ones that you can buy at Highland Park but I had them use the really good steel.
Tony
Post by catmandewe on Sept 16, 2020 17:49:20 GMT -5
Which saw is this off of?
charleslleaf
Post by charleslleaf on Sept 17, 2020 10:45:29 GMT -5
Which saw is this off of? An old 14" Highland Park Slab Saw. I was finally able to find an arbor shaft that will fit. Appreciate everyone's help here. Thanks so much.
