skye
Member since September 2020
Post by skye on Oct 10, 2020 18:40:44 GMT -5
Hey yall! Im about to start tumbling my first batch of fluorite and i'm super excited! Do you have any tips for this newbie?! It would be greatly appreciated
rockstock
Member since April 2019
Post by rockstock on Oct 10, 2020 19:23:10 GMT -5
Don't do Fluorite as a newbie I haven't tried any yet but hear it's a difficult task, good luck see what happens!
lordsorril
Member since April 2020
Post by lordsorril on Oct 10, 2020 21:03:57 GMT -5
Fluorite is soft and has some quirks, it is not beginner friendly...even experienced members have difficulty getting a polish on it. If you plan on tumbling it regardless...my recommendations: -You may want to preshape it using a dremel tool (or an angle grinder-for a larger piece)-since it wears down fast: you don't want to lose too much mass in a tumbler to grind off a specific defect -Tumble it only with other fluorite from the same origin -Start at a fine grit of SiC (120/220) rather than a coarse one (60/90) -Check daily during coarse grind-pull individual pieces out if they are acceptable -Use plastic pellets if you start to see it chip or fracture during coarse-continue to use cushioning at all other stages: I recommend plastic pellets-backfilled to 3/4 barrel. (Preferably pellets that have already been through polish) -If using plastic pellets then keep the SiC exposed pellets separate from the AO ones to prevent SiC carrying over to later stages (for harder stones-not as concerned) -If your pieces start to show new chips/fractures then increase the amount of cushioning via raising the water level Note: During shaping I've had success adding polished quartz gravel (to replace shaped material removed from the barrel), I hand-select the quartz pieces in advance so there are no odd shapes which can create bruising. As for polish: I cannot comment on rotary polish. I have never rotary polished any of this material. Vibe tumbling is pretty easy on smaller pieces using a thick slurry. I have not vibe polished any large pieces yet. If your fluorite is embedded in quartz...then you have a different set of issues (e.g. Photo #6 Snakes and Stones). Good Luck!
skye
Post by skye on Oct 11, 2020 22:42:33 GMT -5
Thank you so much!
