chadf
Member since October 2020
Post by chadf on Oct 10, 2020 20:04:13 GMT -5
Hello All- Thanks for having me in this group. I have been collecting rocks for a while but am new to tumbling. I am having problems with My Lot-O-Tumbler. I followed directions precisely and first batch of agates/quartz rocks came out great. Love the polished look compared to my rotary tumbler. However I am now having problems. My latest batch are not coming out with the polished look after the 3rd stage. I have cleaned the barrel very well before this stage. I also had a problem with the rocks not even moving but an adjustment to fans seems to have solved that problem. I still feel like maybe there is a problem with the vibratory tumbling action (don't even know if this is possible). I have run the rocks (mostly agates) now through a couple of times on the 3rd stage with no luck. I am just not getting that polished look that the first batch had. I have the unit mounted on two cinder blocks very securely. Any suggestions or tips would be much appreciated. I really appreciate this forum being here. I am looking forward to scanning through all the posts.
Post by hummingbirdstones on Oct 10, 2020 22:08:16 GMT -5
Welcome from Northern Arizona!
I don't tumble, so can't help with your problem, but lots of folks here have Lot-Os and will be around to help you out.
Post by rockjunquie on Oct 11, 2020 0:01:38 GMT -5
Welcome from Virginia.
You may want to post your question in the tumbling section, too. It will probably be seen by more tumblers there.
Post by opalpyrexia on Oct 12, 2020 10:42:29 GMT -5
Welcome from Washington.
Post by oregon on Oct 12, 2020 10:45:25 GMT -5
check to make sure the springs aren't broken (esp only one of the back two). Sounds like you've aligned the fan counterweights already...
Post by stephan on Oct 12, 2020 21:41:49 GMT -5
Welcome from NorCal
Post by Fossilman on Oct 14, 2020 11:26:43 GMT -5
Howdy from Oregon... Go to tumbling section, they will help you out...
Post by TheRock on Mar 15, 2021 22:47:42 GMT -5
Welcome to RTH Forum from S/W Michigan! ~Duke
