buroak
Member since October 2019
Post by buroak on Oct 20, 2020 15:31:00 GMT -5
I have an odd question. Would tumbling fine sand (mainly siliceous with hardness from 6.0 - 8.0 & mesh size 30 or finer) help round the grains or is there not enough weight to get the job done? Would be using 12 lb Lortone tubs. I could throw in some small Sioux Quartzite tumbling cubes if that would speed things up and not be too destructive. I have access to a type of sand I would like to use for my aquariums, but the grains are subacute and a bit too sharp for my sand filtering fish. Thanks!
bdport67
Are you licking that?!
Member since September 2020
Post by bdport67 on Oct 20, 2020 15:46:20 GMT -5
Maybe?...but would you trust it with your fish? How much would you have to inspect with a magnifier to be sure? Is it ok if it 90% works?...60%?...How bad would it harm the fish?
I'd just buy the correct type of substrate and not risk it.
buroak
Post by buroak on Oct 20, 2020 15:56:09 GMT -5
There is no "correct" substrate. Way too fine to normally be used in aquariums. Other available sands that "may" have smoother grains are not the color I am looking for. To put this in perspective, the grain size I would like is half that of pool filter sand or less. Think a third of a millimeter give or take. Some play sands meet the size and shape but have a wider range of grain size than I would like and the wrong color, and often contain unknown aggregate types.
edited: Sorry, I didn't answer your question. The sand is most likely safe for the fish in its original state, I would just like to round it off a bit more just to be safe. It is about the size of extra rough tumbling grit.
EricD
High in the Mountains
Member since November 2019
Post by EricD on Oct 21, 2020 7:58:39 GMT -5
Yes, any movement between the grains of sand will round their sharp edges, and if you are able to add a large stone, that will decrease the time it takes to round them to your liking. It may take a couple of weeks or more to achieve what you are trying to do, but it can be done.
buroak
Post by buroak on Oct 22, 2020 14:22:34 GMT -5
Thanks for the reply. I'll give it a shot and see what happens.
