JBe
Post by JBe on Nov 17, 2020 12:59:10 GMT -5
Has anyone seen barrel lid gaskets for a Lortone QT66/12 tumbler in stock anywhere lately? I burned through one right at the beginning of the pandemic and have been running my only spare since then. I feel like I'm living on borrowed time now. I've been regularly checking for available stock at all the usual places but they remain out of stock everywhere I look. I was just curious if anyone has had any luck finding them anywhere.
lordsorril
Member since April 2020
Post by lordsorril on Nov 17, 2020 14:03:18 GMT -5
The Rock Shed had them a few days ago. I ordered a bunch...looks like I was not the only one...seems they are out of stock again...
JBe
Post by JBe on Nov 17, 2020 15:45:11 GMT -5
The Rock Shed had them a few days ago. I ordered a bunch...looks like I was not the only one...seems they are out of stock again... I've been looking there but must have bad timing. It's good to know they have been in stock at some point though. I'll keep checking. Thanks for posting!
chapslv
Member since June 2020
Post by chapslv on Nov 17, 2020 16:08:08 GMT -5
I got one too about a month ago. You can call The Rock Shed and Shawn will tell you when he expects more. They have great customer service.
Post by As I in does tries! on Nov 17, 2020 19:28:44 GMT -5
Greetings if everywhere is currently out of stock you can try just repairing it yourself, it is the same as repairing rubber boots.
NevadaBill
Post by NevadaBill on Nov 20, 2020 14:07:33 GMT -5
Greetings if everywhere is currently out of stock you can try just repairing it yourself, it is the same as repairing rubber boots. This is a really cool MacGyver kind of a fix. Thanks for posting this idea!
inbtb
Member since May 2016
Post by inbtb on Nov 20, 2020 15:42:15 GMT -5
Where is it worn through? I have a QT-6 that needed some work on the bolt head. Smoothed out with a coat of epoxy no leaks since.
inbtb
Post by inbtb on Nov 20, 2020 15:48:20 GMT -5
PM me your address and I'll stick 1 in the mail.
Post by aDave on Nov 20, 2020 16:08:25 GMT -5
Has anyone seen barrel lid gaskets for a Lortone QT66/12 tumbler in stock anywhere lately? I burned through one right at the beginning of the pandemic and have been running my only spare since then. I feel like I'm living on borrowed time now. I've been regularly checking for available stock at all the usual places but they remain out of stock everywhere I look. I was just curious if anyone has had any luck finding them anywhere. As a stopgap to reduce gasket wear, place a piece of duct tape over the bolt end on the metal lid (between the gasket and the lid). That's a spot for wear, and the duct tape will really help to reduce it. I know that's not what you asked about, but this may help to extend the life of your gasket.
Post by quartz on Nov 20, 2020 22:47:29 GMT -5
If you are talking of the flat round disc, I've cut them out of thick pond liner material.
QuailRiver
Post by QuailRiver on Nov 21, 2020 0:40:40 GMT -5
If you have a local industrial supply company check and see if they have rolls of neoprene rubber in stock. Our local store has 3' wide rolls that they will sell cuts from by the linear foot for around $1 per square foot (the last time I purchased). I've cut several gaskets for saws and one for a tumbler from this material and they have all worked well.
Larry C.
JBe
Post by JBe on Nov 23, 2020 11:14:55 GMT -5
I love how the members here are so supportive of each other! Thanks to everyone who offered advice. I appreciate it.
I do use duct tape to cover the bolt head on the lid under the gasket. It does help extend the life.
I think I'll try an experiment with epoxy on one of my lids.
If/when the current gasket wears through I'll try one of the suggested McGyver methods.
JBe
Post by JBe on Nov 23, 2020 11:17:04 GMT -5
PM me your address and I'll stick 1 in the mail. Thank you for the offer! I'm not down yet so I'll keep checking stock at the dealers. I may take you up on your offer if I do get totally stuck.
EricD
High in the Mountains
Member since November 2019
Post by EricD on Nov 23, 2020 13:22:47 GMT -5
I love how the members here are so supportive of each other! Thanks to everyone who offered advice. I appreciate it. I do use duct tape to cover the bolt head on the lid under the gasket. It does help extend the life. I think I'll try an experiment with epoxy on one of my lids. If/when the current gasket wears through I'll try one of the suggested McGyver methods. RocksInNJ uses a couple bandaids crossed over each other over the bolt head to cushion the impact of rocks against it. I believe he has gotten good performance out of that method.
