petoskeycheryl
Can't wait for spring in Michigan.
Member since November 2019
Post by petoskeycheryl on Nov 19, 2020 20:24:15 GMT -5
I have some rocks that are very pretty but they have been coated with Amazing Clear Coat Epoxy about a year ago. ( Now this is before someone in our household got their first tumbler and they really did not know better. And yes, this person may or may not be me, depending on your replies). So my question is, can I safely remove this by tumbling them in stage 1 or would I ruin my brand new Lortone QT6 that the Big Brown Truck left on my doorstep this very afternoon? Sure would not want to mess up that new pretty barrel. Any other options to removing it? I also own a Lot O Tumbler but I was thinking that will never work.
Post by jasoninsd on Nov 19, 2020 20:30:39 GMT -5
I can't say yay or nay...but my guess is going to be it shouldn't be a problem. I'll be curious to see what the more experienced have to say on it. Congrats on the big brown truck delivery!!! And if you ever find "that person" who clear coated them, just forgive them...we all...I mean "they" all...make mistakes.
EricD
High in the Mountains
Member is Online
Post by EricD on Nov 19, 2020 20:32:35 GMT -5
The grit will remove pretty much anything. Go ahead and run it in the lot-o or the rotary
petoskeycheryl
Post by petoskeycheryl on Nov 20, 2020 0:24:26 GMT -5
I was worried it might damage the inside of the barrel in some way or get all gunky.
Post by pauls on Nov 20, 2020 1:30:59 GMT -5
Grit removes rock, it will not have a problem with a bit of epoxy.
Post by rmf on Nov 20, 2020 4:00:07 GMT -5
petoskeycheryl epoxy is more abrasion resistant than petoskey stone. That means that grinding to remove the epoxy may give results you don't want like removing the hard candy off the tootsie roll in a tootsie pop. but if you don't care then grind away it is easy. the more controlled option is to soak the petoskey stones in acetone. I picked up a little walmart glass jar with wire latch and a silicone seal ($6) that I used to soak cabs off dops that had been put on with CA. This had a slight leak so over a month or 2, acetone evaporated out. My second attempt was a crock type jar about 4" in diameter and 8" tall with a silicone gasket and wire latch($4). This I picked up at a thrift shop and keeps acetone for months with no leaks. Thrift shop was a better deal. soak stones in acetone and then tumble.
petoskeycheryl
Post by petoskeycheryl on Jan 8, 2021 1:49:49 GMT -5
Thanks for your replies everyone. I ran them in the Lortone QT6 and you all were right. No problem at all. It was like that little epoxy episode never happened.
Prov
Member since March 2020
Post by Prov on Jan 9, 2021 14:27:03 GMT -5
Got any pictures? We'd love to see what you came out with!
petoskeycheryl
Post by petoskeycheryl on Jan 9, 2021 16:24:12 GMT -5
I will have to learn how to post pictures here. I will post when I have done that. Everyone loves for someone to say Can I see a picture of your rocks?
Post by Tommy on Jan 9, 2021 16:48:50 GMT -5
I will have to learn how to post pictures here. I will post when I have done that. Everyone loves for someone to say Can I see a picture of your rocks? Around here we like to say - photos or it didn't happen! Glad this is working out for you. If you need help with the photo hosting thing let us know.
