Post by holajonathan on Dec 24, 2020 13:10:35 GMT -5
I am wondering if anyone has used this tool for pre-shaping / grinding rocks for tumbling. I have had good luck with Dremel brand tools, and it costs half of a Foredom. I am a casual rock tumbler. It might get 15-20 minutes a week of use. Thanks in advance for any help!
Post by miket on Dec 24, 2020 13:22:16 GMT -5
I use a dremel to cab, I usually get an hour or so a night of use with mine. It's not a flex shaft, however...
Post by manofglass on Dec 24, 2020 14:12:28 GMT -5
I use a dremel to cab, I usually get an hour or so a night of use with mine. It's not a flex shaft, however... A cabber would be faster miket How you coming on that
Post by miket on Dec 24, 2020 17:11:36 GMT -5
I use a dremel to cab, I usually get an hour or so a night of use with mine. It's not a flex shaft, however... A cabber would be faster miket How you coming on that Slowly my friend, slowly...
Post by rockjunquie on Dec 24, 2020 19:28:27 GMT -5
I use a dremel to cab, I usually get an hour or so a night of use with mine. It's not a flex shaft, however... A cabber would be faster miket How you coming on that Love the subtle hints.
Post by hummingbirdstones on Dec 24, 2020 19:35:47 GMT -5
A cabber would be faster miket How you coming on that Love the subtle hints. Me too. I almost spit my coffee out!
Post by miket on Dec 25, 2020 8:01:29 GMT -5
Yeah. Hilarious. 🤣
Post by rockjunquie on Dec 25, 2020 8:17:07 GMT -5
Just playing with you, Mike. You know we love you.
NDK
Post by NDK on Dec 25, 2020 9:15:52 GMT -5
holajonathan If you're handy, a flat lap is simple to build and will get you farther than a dremel. Check out the home made equipment section if that's an option for you... Otherwise... I have one of these and love it. They have great reviews and an even better price. 1/4 the price of the dremel you are inquiring about - giving you more $ to spend on rocks 😉 www.harborfreight.com/flexible-shaft-grinder-and-carver-40432.html
Post by stardiamond on Dec 25, 2020 10:41:04 GMT -5
There is a slower way to make a cab than a Dremel; sandpaper.
Post by victor1941 on Dec 25, 2020 13:09:06 GMT -5
Halojonthan, I use a flex shaft with success for a few stones when polishing/buffing but find it is a really good tool for other jobs around the home. We recently helped a neighbor remove a corroded/leaking toilet tank bolt by grinding away the flange using a diamond bit. The flex shaft for the Dremel is much cheaper and will let you know if you like holding the hand piece when working.
Post by miket on Dec 26, 2020 5:56:24 GMT -5
Just playing with you, Mike. You know we love you. Oh I know you are.... 😁
