agateangler
Member since December 2020
Post by agateangler on Dec 26, 2020 23:27:49 GMT -5
Hello,
So I noticed part way through my last batch that the lower 2 cm portion of the barrel had been 'smoothed' out and then I noticed some residual rubber on both of the shafts. I was not sure what the problem was until I took a little closer inspection and noticed that when I plug the tumbler on (with the barrel in place) the drive shaft is moving slowly in and out. This is not as much the case when I take the barrel off. I tried tightening the belt and maybe noticed a little less movement on the shaft, but it is still there. My question is whether anyone else has experienced this before and has any suggestions.
