jlcochran42
Member since July 2020
Post by jlcochran42 on Dec 27, 2020 0:29:25 GMT -5
I'm having a difficult time distinguishing from different types of gemstones. Is there a reference guide somewhere to help me? How did all of you learn how to identify the different types of gemstones?
Post by rmf on Dec 27, 2020 5:13:06 GMT -5
Learn your mineral physical properties, these can be found in most any mineral book or college minerlogy text. A rocks is defined as being composed of 1 or more minerals, If you want to learn about rocks then select a college petrology (study of rocks) textbook. Gemstones are a sub category of these two. Some suggested books: Dana's Manual of Mineralology, Hurlbut, Cornelius S., Jr. Ph. D., ISBN 0-471-42225-8 A Field Guide to Rocks and Minerals, Pough, Frederick H. Rocks and Minerals, A Golden Nature Guide, Zim, Herbert S. <= less technical but drawings are good and info is good beginner guide
If you are an old fart I have heard that the local university will allow you to audit a class with permission. Not sure if it is true but if you could audit (no college credit- No cost) a class on minerology or historical geology these will also help. When I retire I was going to check that out. Distance learning is not good for minerals. you have to touch to study.
kyoti
Member since June 2020
Post by kyoti on Dec 27, 2020 9:15:28 GMT -5
This is a pretty good reference too. It has pictures of finished and rough Rock and Mohs hardness as well as UV and other statistics. I also used Google, Etsy and forums extensively when I first started trying to learn about some of the materials I was Finding.
gatorflash1
Post by gatorflash1 on Dec 27, 2020 9:56:16 GMT -5
jlcochran42
Post by jlcochran42 on Dec 27, 2020 13:55:23 GMT -5
Thank you. I will definitely check out these books.
